Integration of Fibaro Dimmer 2 in Din Rail housing
Posted: Thursday 14 January 2016 20:54
by Quax1507
I integrated a Fibaro Dimmer 2 into an empty DIN Rail housing (german Hutschiene) for mounting in electrical Distributor box.
I removed the cover from Dimmer 2 and had to cut the plastics (green) of the connector a few millimeters to fit inside.
You can buy empty housings at http://www.conrad.com
Quaxx
Re: Integration of Fibaro Dimmer 2 in Din Rail housing
Posted: Wednesday 20 January 2016 21:06
by JacquesMulders
Witch housing did you use, there are so many... do you have a order nr?
Posted: Thursday 21 January 2016 7:35
by proohu01
JacquesMulders wrote:Witch housing did you use, there are so many... do you have a order nr?
I think this is what you are looking for....
https://www.conrad.nl/nl/axxatronic-din ... 32664.html
Posted: Thursday 21 January 2016 7:56
by Quax1507
