How to generate a short (1 second) negative pulse
PBdA
Domoticz version: 3.5893
Post by PBdA »
I have a zwave relay (Qubino ZMNHND1 Flush 1D relay) which commands an alarm. The relay is normally closed and to arm or disarm alarm, it should open for a short time and then close. I have tried a lua script:
commandArray[1] = {['Alarm command'] = 'Off'}
commandArray[2] = {['Alarm command'] = 'On AFTER 1'}
but it does nothing. This works only for a pulse >= 3 seconds:
commandArray[2] = {['Alarm command'] = 'On AFTER 3'}
It's possible to generate a short positive pulse with a scene:
Command: On
On delay: 0
Off delay: 1
But it doesn't work for an Off command:
Command: Off
On delay: 1
Off delay: 0
Switch goes Off immediately but never return to on.
PBdA
jautem
Domoticz version: 2.3530
Re: How to generate a short (1 second) negative pulse
Post by jautem »
can you use sleep function in lua script , turn off , sleep 3 et turn back on ?
raspberry cam - moteino rfm69 - Zwave Stick - IR - 433 transceiver
PBdA
Post by PBdA »
jautem wrote:can you use sleep function in lua script , turn off , sleep 3 et turn back on ?
Sleep is a bad thing in lua script because it blocks execution of other scripts. Furthermore, I think it doesn't work because commandArray is executed at once when script return.
PBdA
jautem
Post by jautem »
so perhaps fork another script like shell in lua source script , and shell script will sleep and use api to finish job ?
PBdA
Post by PBdA »
Nice idea but I have taken another way: Qubino ZMNHND1 Flush 1D relay can be configured to return to On by itself with a configurable delay. I had to use a recent OpenZwave config but it works.
Thank you for your help.
PBdA
