Awave.me Zwave+ -vs- Aeotec Z-StickS 2 Controller
btedeski
Post by btedeski »
I have both installed on a Raspberry Pi
Aeotec Z-Stick S2 /dev/ttyUSB0
Z-Wave.Me RaZberry Controller ZWave+ /dev/ttyAMA0
Currently only the Aeotec S2 is configured, it is handy because I can carry it around to add devices
but for long term use, which controller is the better,
Any thoughts?
Bill
nayr
Domoticz version: github
Re: Awave.me Zwave+ -vs- Aeotec Z-StickS 2 Controller
Post by nayr »
My Aeotech S2 has never let me down, being portable is a must for me.. my domoticz server is locked in a steel cabinet in my basement, not exactly best place to put a RF transceiver.. so I have a 35ft USB cord following an HDMI cable to behind my living room TV, this goes into a powered hub that holds the Z-Stick (and a usb to serial adapter hooked to TV).. Now my controller is right smack dab in the middle of my house and nearly everything has a direct signal to it.
Z-Stick can run on anything, not limited to a pi only.. if you want to use something else hardware wise its as easy as plugging it in and going.
I dont like being locked down into a platform, there are bigger and better things out there than RPI's, they are simply the most popular.
