Send TT=0
Posted: Tuesday 12 January 2016 10:14
by Softwareregi
I'm a newby in Domoticz land, so ...... be patient
- How do I create a button that sends the command TT = 0 to the OTGW
- is it possible to have all the buttons (temp, pressure, setpoint, and so on) of the otgw on one tab and not, as now, on several tabs
gr. John
Re: Send TT=0
Posted: Thursday 04 August 2016 16:06
by manjh
Looking for that tt=0 button as well John, will let you know when I find a way.
As for the second question: Create a "roomplan"for OTGW.
Setup-->more options-->plans-->roomplan
Then add all required OTGW buttons to the plan.
When done, for instance on the dahboard select the OTGW plan in the right-upper corner.
Re: Send TT=0
Posted: Friday 26 October 2018 10:41
by pjotr
Is there a way to send the command TT=0 from Domoticz ? I want te set the temperature at 16 degrees when i leave home. When i come back home i want to set the temperature to the default temp of the thermostat program.
Re: Send TT=0
Posted: Friday 26 October 2018 10:44
by mvzut
pjotr wrote:Is there a way to send the command TT=0 from Domoticz ? I want te set the temperature at 16 degrees when i leave home. When i come back home i want to set the temperature to the default temp of the thermostat program.
I just set the thermostat to 0, works perfectly.
Re: Send TT=0
by emme
how do you connect to the OTGW?
MQTT? API?
you can create a simple pushbutton and a script that will send the TT=0 payload to the OTGW, but I have no experience with OTGW
ciao
M
Re: Send TT=0
Posted: Friday 26 October 2018 10:57
by pjotr
I am curious how you sens the TT=0 command to the OTGW from domoticz ? If it is possible with a script i can trigger this script in domoticz events.
Send TT=0
Posted: Saturday 27 October 2018 7:24
by mvzut
pjotr wrote:I am curious how you sens the TT=0 command to the OTGW from domoticz ? If it is possible with a script i can trigger this script in domoticz events.
My OTGW is connected to my Raspberry Pi with a USB-to-serial adapter. The thermostat which the OTGW plugin creates basically sends TT commands when you change its value. So I just set the value of the thermostat to something low when I leave the house, and to 0 when I come back home, effectively switching back to timer mode. I use a LUA command for this:
commandArray['UpdateDevice'] = otherdevices_idx['Thermostat']..'|0|0'
But you can obviously also do this with Blockly, Python, shell scripts, whatever you prefer.
Re: Send TT=0
Posted: Sunday 08 November 2020 8:19
by CaptainSlow
Im reviving this topic with a new topic as I found out this url works perfectly fine.
http://<ip>:<port>/json.htm?type=command&param=sendopenthermcommand&idx=<idx>&cmnd=<cmnd>
https://domoticz.com/forum/viewtopic.php?f=26&t=34506
