Speed up 1-wire reads with simualtenous conversion!
Posted: Monday 11 January 2016 18:31
I have 25 1-wire temperature sensors, and I will add another 20. I'm using Domoticz native OWFS-support.
Domoticz is reading from the unchached directory (hardware/1Wire/1WireByOWFS.cpp), so every sensor takes about 750 ms to read.
With a hardcoded 1-wire polling interval of 30 seconds (hardware/1Wire.cpp) it will not finish in time when I add more sensors!
OWFS can issue a command to ALL temperature and voltage sensors o do a conversion simulatenously, and then the data is available directly after the conversion.
I changed the path in 1WireByOWFS.cpp to not read from the "uncached", and wrote "1" to the simulatenous temperature manually in a ssh-session just before Domoticz started to read. Here is the difference:
WITHOUT simulatenous conversion:
WITH simulateous conversion:
A reduction from 17,97 to 2,03 seconds! (0,72 to 0,08 seconds/sensor).
Now, I can't figure out exactly how Domoticz gather the data, but I would like Domoticz to write 1 to mnt/1wire/uncached/simulatenous/temperature just before it starts to read temperature ensors, and 1 to /mnt/1wire/uncached/simultaneous/voltage just before it starts to read 1-wire devices with analog input.
Since OWFS has a default cache time of 15 seconds, I guess it would work perfect just to write 1 to both temperature and voltage just before the periodic 1-wire data readout every 30 seconds.
Anyone know where the code to write the two ones to the right file should be placed?
pi@pi2 /mnt/1wire/uncached/simultaneous $ echo 1 > temperature
pi@pi2 /mnt/1wire/uncached/simultaneous $ echo 1 > voltage
2016-01-11 18:23:08.350 (OWFS) Temp (Frys)
2016-01-11 18:23:09.101 (OWFS) Temp (Kyl)
2016-01-11 18:23:09.855 (OWFS) Temp (Köksbänk)
2016-01-11 18:23:10.582 (OWFS) Temp (OWFS-test)
2016-01-11 18:23:11.338 (OWFS) Temp (GV-retur: Dusch)
2016-01-11 18:23:12.085 (OWFS) Temp (GV-retur: Kök)
2016-01-11 18:23:12.835 (OWFS) Temp (GV: Tillopp VVX)
2016-01-11 18:23:13.586 (OWFS) Temp (GV: Retur VVX)
2016-01-11 18:23:14.334 (OWFS) Temp (GV-retur: Vard3)
2016-01-11 18:23:15.086 (OWFS) Temp (GV-retur: Hall)
2016-01-11 18:23:15.845 (OWFS) Temp (GV-tillopp: Kök)
2016-01-11 18:23:16.597 (OWFS) Temp (GV-tillopp: Dusch)
2016-01-11 18:23:17.347 (OWFS) Temp (GV-retur: Klv)
2016-01-11 18:23:18.095 (OWFS) Temp (GV-tillopp: Klv)
2016-01-11 18:23:18.841 (OWFS) Temp (GV: Tillopp fördelare)
2016-01-11 18:23:19.592 (OWFS) Temp (V: Retur: Garage)
2016-01-11 18:23:20.342 (OWFS) Temp (GV-retur: Vard4)
2016-01-11 18:23:21.090 (OWFS) Temp (Tillopp: Garage)
2016-01-11 18:23:21.838 (OWFS) Temp (GV-tillopp: Kontor)
2016-01-11 18:23:22.585 (OWFS) Temp (Gv-retur: Kontor)
2016-01-11 18:23:23.332 (OWFS) Temp (GV-tillopp: Vard4)
2016-01-11 18:23:24.080 (OWFS) Temp (GV: Bypass)
2016-01-11 18:23:24.826 (OWFS) Temp (GV-tillopp: Vard3)
2016-01-11 18:23:25.573 (OWFS) Temp (GV: Retur fördelare)
2016-01-11 18:23:26.321 (OWFS) Temp (GV-tillopp: Hall)
2016-01-11 18:24:46.083 (OWFS) Temp (Frys)
2016-01-11 18:24:46.178 (OWFS) Temp (Kyl)
2016-01-11 18:24:46.267 (OWFS) Temp (Köksbänk)
2016-01-11 18:24:46.342 (OWFS) Temp (OWFS-test)
2016-01-11 18:24:46.431 (OWFS) Temp (GV-retur: Dusch)
2016-01-11 18:24:46.520 (OWFS) Temp (GV-retur: Kök)
2016-01-11 18:24:46.608 (OWFS) Temp (GV: Tillopp VVX)
2016-01-11 18:24:46.696 (OWFS) Temp (GV: Retur VVX)
2016-01-11 18:24:46.783 (OWFS) Temp (GV-retur: Vard3)
2016-01-11 18:24:46.873 (OWFS) Temp (GV-retur: Hall)
2016-01-11 18:24:46.964 (OWFS) Temp (GV-tillopp: Kök)
2016-01-11 18:24:47.061 (OWFS) Temp (GV-tillopp: Dusch)
2016-01-11 18:24:47.160 (OWFS) Temp (GV-retur: Klv)
2016-01-11 18:24:47.248 (OWFS) Temp (GV-tillopp: Klv)
2016-01-11 18:24:47.335 (OWFS) Temp (GV: Tillopp fördelare)
2016-01-11 18:24:47.421 (OWFS) Temp (V: Retur: Garage)
2016-01-11 18:24:47.508 (OWFS) Temp (GV-retur: Vard4)
2016-01-11 18:24:47.595 (OWFS) Temp (Tillopp: Garage)
2016-01-11 18:24:47.684 (OWFS) Temp (GV-tillopp: Kontor)
2016-01-11 18:24:47.770 (OWFS) Temp (Gv-retur: Kontor)
2016-01-11 18:24:47.857 (OWFS) Temp (GV-tillopp: Vard4)
2016-01-11 18:24:47.943 (OWFS) Temp (GV: Bypass)
2016-01-11 18:24:48.031 (OWFS) Temp (GV-tillopp: Vard3)
2016-01-11 18:24:48.119 (OWFS) Temp (GV: Retur fördelare)
2016-01-11 18:24:48.206 (OWFS) Temp (GV-tillopp: Hall)
