GW PowerNode 1 port - "usage,electric" seen twice in devices
Posted: Sunday 10 January 2016 11:35
Hello everyone!
My first post in this forum and it is regardin the greenwave powernode 1 port switch and energy meter.
I am running Raspberry PI, Domoticz version 2.4031 (beta channel) and the razberry controller.
I am using openzwave via USB to control razberry and the zwave network.
The only problem I have right now (2x multisensors working fine) is that the greenwave powernode 1 port reports the electric usage twice in watts. I would expect one device to show up as electric, KWH or similar. Instead i have two devices that reports exactly the same thing. I have tried to exclude/include the device several times, but no change.
Also, in the openzwave control panel the values are reported properly, one for watt usage, one for kwh usage.
I am attaching 3 screenshots from the hardware tab, device list and the openzwave control panel for further info on what I am seeing.
Any thoughts?
Thank you and regards
/Fredrik
Any thoughts?
/Fredrik
