CURL to LUA
tms5d
CURL to LUA
Post by tms5d »
I have several really simple CURL scripts, and have to translate them to LUA to run them from my RasPi. To be honest, I just can't figure out how to do that.
For example, I'm using this CURL-script to reboot my IP cam(s):
curl -X PUT --user user:password http://192.168.0.18/system/reboot
I'd really appreciate some help translating this piece of code to LUA. This will help me to translate the other scripts myself.
Thanks!!
jvdz
Domoticz version: 4.107
Re: CURL to LUA
Post by jvdz »
I haven't tried it but guess it should be something like this:
	commandArray['OpenURL']='http://user:[email protected]/system/reboot'
Jos
tms5d
Re: CURL to LUA
Post by tms5d »
Thanks, trying to figure this one out:
I created the script:
And attached the script to a virtual switch like this:
and lo and behold ... nothing happens :) So I'm doing something wrong I guess?
Any kind of help would be greatly appreciated.
jvdz
Re: CURL to LUA
Post by jvdz »
Don't put the LUA script in the "On Action" but name it correctly as defined here: https://www.domoticz.com/wiki/Events
So rename the file to script_device_xxxxx.lua. All script_device_???.lua scripts are fired each time a device changes.
Jos
tms5d
Re: CURL to LUA
Post by tms5d »
thanks, works! just curious, why can I not use "on action" to activate a script?
jvdz
Re: CURL to LUA
Post by jvdz »
You can activate it like that, but as far as I know, the script will have to perform all tasks stand-alone with JSON call as no Arrays are passed not will returned commandArray() be processed by the Domoticz event system.
Jos
