Hello everyone,
First post here as i've only been using Domoticz (2.4031) for a few days.
I've built it on Debian linux (v8.2) following the wiki page instructions and managed to get OpenZWave working ok with a couple of Fibaro sensors but I'm struggling with Blockly.
I have some Lua scripts running such as the PIR script from the Alarm Setup wiki page but i can't seem to get Blockly to do anything. Here's a simple one i'm testing.
If i manually set the variable to 1 nothing happens. No entry in the log or anything. I do see log entries for the Lua scripts though.
Am I doing something dumb or is there some other component I should have installed? Is there any extra logging i can check?
Phil
Blockly not running
Philosifer
- Domoticz version: 2.4223
D'rMorris
Re: Blockly not running
Did you create the uservar as text? Or integer? I don't have access to blockly now (doesn't work on safari / iphone) but you are now checking for a string "1". If I remember correctly, the number blockly is a different color?
Philosifer
Well spotted D'rMorris. You're right the variable is an Int and I have a string to compare to it
That fixed it thanks.
One of the problems with drag and drop is you don't have think so much about what you're doing.
Let's hope my next post is more challenging for you all
Phil
Phil
D'rMorris
Glad to be of assistance Phil
. Sometimes it's the small things that cause the biggest problems
