Page 1 of 3
StellaZ vs Danfoss Living connect vs Komforthaus Comet ?
Posted: Friday 08 January 2016 15:52
by xender
Hello everyone,
I looking for Z-wave thermostat and I would like to have your feedback about different product I found :
- EUROTRONIC - Vanne Thermostatique Z-Wave StellaZ :
http://www.eurotronic.org/en/produkte/stella-f.html
- Komforthaus - Thermostat de radiateur Comet Z-Wave :
http://www.komforthaus.fr/epages/646526 ... 00-100-418
- Danfoss living connect 014G0001 :
http://products.danfoss.com/productdeta ... /014g0001/
I know there are other solution but they are proprietary protocol and they need proprietary box and I don't like that very much.
Thanks !
Re: StellaZ vs Danfoss Living connect vs Komforthaus Comet ?
Posted: Friday 08 January 2016 17:17
by Egregius
I like the Danfoss valves. Have 6 of them and they do what they are supposed to do.
I once had a StellaZ but never got it operational.
The Smartwares valves before that didn't last that long, they definitely didn't fullfill my expectations.
Posted: Saturday 16 January 2016 15:52
by draggho
I have no experience with Danfoss.
Comet Z is also EUROtronic product - it's actually next generation of StellaZ. Comparing to Danfoss it can report temperature from sensor. I have one and I;m currently experimenting with it. so I will have some feedback in couple of days.
Posted: Sunday 17 January 2016 13:37
by xender
Posted: Sunday 24 January 2016 15:23
by mKotek
draggho wrote:I have no experience with Danfoss.
Hi draggho,
Can you post your findings re Comet Z-wave? I have purchased one as well, and level, status, temperature and setpoints are visible in Domoticz, but I have issues with module responding to my settings. I would be very interested in your experience.
Posted: Sunday 24 January 2016 16:59
by pdjm43
I bought 6x StellaZ a year ago, tried them with polling and they were terrible, kept going offline. My code was reading the valve open state, which would stop responding to the polling.
But I just found someone has posted the setpoint control from lua. Now I dusted them off and refitted them, I have them set to wake 240, no polling, set to comfort and send the comfort setpoint at 28 whenever I need heat in the room and send to 17 when I don't. They all work and have been 100% for the last week.
Posted: Monday 25 January 2016 18:39
by mKotek
pdjm43 wrote:I bought 6x StellaZ a year ago, tried them with polling and they were terrible, kept going offline. My code was reading the valve open state, which would stop responding to the polling.
I have set my to setpoint eco in the morning and it has responded almost immediately.
So I have setup plans to change setpoints at different times during the day. Setpoints were changed within 4 minutes of the time set, but Comet has not responded to my action. That is, the setpoint for comfort has been updated according to control panel (set to 24 degrees from 18 on eco), but unfortunately, the setting has not resulted in any action on the valve for the next 30 minutes - on the display, it was still showing 18 deg. Only when I have changed it manually, the valve has been acted upon and changed to desired setting.
I still think, it might be because OpenZWave needs to wake them up in a different way (device is identified as beamable, meaning, proper wakeup call can be sent every minute, not necessarily waiting for wakeup interval, but I am no specialist here, so 1) I might be wrong, 2) I do not know, how to solve it.
Posted: Tuesday 26 January 2016 10:57
by xender
If someone is using Danfoss LC-13 can they please give us the screenshot of the settings on Domoticz? Because I still have an E5 error after about 1 hour connected
My time out is 1800 secondes for wake up interval.
Posted: Wednesday 03 February 2016 4:59
by pdjm43
I tried using the GUI setpoint edit and it wasn't 100%, I use lua and it is 100% working, you can see a log entry for ....sending setpoint.
Posted: Thursday 16 June 2016 9:48
by flexyz
New with this
Where can I find the LUA script and what gateway/base are you using for the Zwave control?
Felix
Posted: Thursday 16 June 2016 12:46
by OCB73
I am using a Raspi with some LC-13.
Oliver
Posted: Wednesday 28 September 2016 19:41
by Sevift
STELLAZ - using the second year
local upTemp = 30
local downTemp = 10
if tempTempHum - tempTsV <= delta then
setTemp = upTemp
elseif tempTempHum - tempTsV >= 0 then
setTemp = downTemp
commandArray[#commandArray+1] = {['UpdateDevice'] = thermostatIdx..'|0|'..tostring(setTemp)}
Posted: Wednesday 28 September 2016 21:01
by Egregius
Isn't 10/30 a bit overkill?
I use a function that sets the valva 1 degree lower or higher for each 0,1 temp difference. That way they're somewere half open if temp is reached.
Posted: Wednesday 28 September 2016 22:12
by Westcott
Egregius, I didn't realise that the StellaZ accepted a setpoint with 0.1 resolution.
Thanks, I'll alter my code to do the same.
Posted: Wednesday 28 September 2016 23:31
by Sevift
Egregius wrote:Isn't 10/30 a bit overkill?
Thanks.
Posted: Wednesday 28 September 2016 23:43
by Egregius
I don't use 0.1 as setpoint. For each 0.1 difference I set 1 degree plus or min.
Examples:
Setpoint room=21, room temperature is 20.8, valve is 23.
Posted: Thursday 29 September 2016 0:01
by Westcott
Oops, sorry! I misread your post.
Good job I haven't hacked any code yet...
Posted: Thursday 29 September 2016 13:14
by Sevift
I have it so
local minTemp = 30
local maxTemp = 10
setTemp = (tempNeed - tempTempHum) * 10 + tempNeed
if setTemp < minTemp then
setTemp = minTemp
if setTemp > maxTemp then
setTemp = maxTemp
Posted: Sunday 09 October 2016 16:32
by guantolento
good afternoon to everyone,
sorry but i have one question.
the stella z has integrated a temperature sensor ? because the danfoss lc-13 need a external temperetur sensor and over the lc-13 i can only set the setpoint.
iam new in this world and now iam testing some danfoss lc-13 but im' not very happy with this device. i have some e5 error. so i think to test some stella z.
Posted: Monday 10 October 2016 23:22
by Szmalu
guantolento wrote:danfoss lc-13 need a external temperetur sensor
No it doesn't. Danfoss works fine as it is. It's got build in temperature sensor (just doesn't reporting temperature state outside).
