Qubino Z-Wave Plus Qubino DIN Dimmer ZMNHSD1
cever
Post by cever »
Hi All,
I'm quite new to all of this, I was wonder if the "Qubino Z-Wave Plus Qubino DIN Dimmer ZMNHSD1" would work in Domoticz.
I ordered 2 of them today, the plan is to build a Domoticz "try" box on linux next week.
Thanks,
Chris
cever
Re: Qubino Z-Wave Plus Qubino DIN Dimmer ZMNHSD1
Post by cever »
Got the 2 dimmers installed they work (more or less) with the standard pulse buttons, however I can't get them into domoticz.
I managed to have my USB stick setup and it shows OK.
When I go to switch -> Learn or manual doesn't work.
I have pressed the dimmer button for 5s -> timeout
I have pressed the USB stick button for 5s -> timeout
If I chose manual setup, I can't select anything in "Hardware" ...
Any ideas ?
Thanks,
Chris
cever
Post by cever »
Solved it :)
I have created a new xml file containing all functionality in this dimmer.
I will post the details shortly.
Regards,
Chris
fixeon
Domoticz version: 3.6587
Post by fixeon »
check for manufacturer and devices xml files here:
https://github.com/OpenZWave/open-zwave/tree/Qubino
it works with my ZMNHSD1 that i just got today!
Raspberry Pi 2 Type B or Arch64 Server (still testing)
RFXTRX433E + Aeotec Z-Stick S2
All pcs running various linux distros including sat receiver
Extreme noob warning :)
Muckydevil
Post by Muckydevil »
I've just purchased the Qubino DIN Dimmer ZMNHSD1 and see we need an updated XML file for it. How do we go about adding this?
Muckydevil
Managed to work it out in the end Doh ;-) It now has been included and is controllable :-) Thanks for the XML!!
