Qubino ZMNHDA2 Flush Dimmer timeout
Posted: Wednesday 06 January 2016 21:30
by maomanna
Since a while I use a Qubino ZMNHDA2 Flush Dimmer
But It never switches with blockly's from OFF to ON.
I always need to press the physical button (pulsbutton) before it switches the % of light.
And when it succeed to switch on, it is very slow, like 3 - 4 seconds before it turns on.
The log shows me that it the node timeouted.
2016-01-06 21:26:24.682 OpenZWave: Received timeout notification from HomeID: 4011846441, NodeID: 4 (0x04)
Anyone an idea how to fix this?
Re: Qubino ZMNHDA2 Flush Dimmer timeout
Posted: Thursday 07 January 2016 11:31
by bbqkees
If the response is slow when you press the physical switch on the wall, I think your light is faulty or you are dimming too low.
Posted: Thursday 07 January 2016 15:40
by maomanna
I use the dimmer with 5 segula led globe 125, which dim nicely.
I'd like to turn on the light when it is dark and my motion sensor is turned on (sees motion).
Most of the time a push on the physical turns on the light almost directly
Posted: Sunday 10 January 2016 22:53
by maomanna
anyone?
Or switch the Qubino for a Fibaro?
Posted: Sunday 10 January 2016 23:41
by Egregius
Timeout is usely range problem. How many main powered devices do you have?
Zwave needs several main powered devices to work stable.
Posted: Monday 11 January 2016 13:16
by maomanna
I use 1 qubino and 2 fibaro main powered devices.
The Qubino is about 9m away from the controller, 1 wall (cellenbeton 7cm) and some kitchendevices are between them.
Maybe that is causing this problem?
1 Fibaro is almost above the Qubino.
Hereby a group overview:
Posted: Monday 11 January 2016 17:35
by Egregius
You already did a network heal?
Maybe someone could explain what the difference in colors mean?
Posted: Wednesday 13 January 2016 12:07
by maomanna
every color is 1 device. This is how it's linked together
