Fibaro wallplug FGWPF-102 can not disable power report
Posted: Tuesday 05 January 2016 8:59
by Gravityz
i just recently started with Z-wabe but i notice a lot of bugs in the config files.
i currently have a Fibaro wall plug FGWPF-102 which is recognised as FGWPE in domoticz.
everything seems to work ok but when you try to change certain parameters you notice that things do not work like they should
for example:
parameter 47 is for specifying the time period after which a power report is generated
default it is set to 3600 seconds which works
accoording to the manual if you set this to 65535 the power report is disabled
65535 however is not accepted.
i did some testing and 32767(15 bits) is the highest possible setting.
also changing the FGWPE.XML file and adjust max to 65535 will not work.
can anybody confirm this or tell me what to change in the XML file.
