What thermostat to choose..
Posted: Monday 04 January 2016 22:26
by solidsjakie
Hi All,
I currently have an Intergas Kobikompakt HRE28/24.
I am controlling it with a Honeywell Chronotherm IV On/Off.
I know my heater supports Modulation/Opentherm, so I would like to replace the thermostat with a better option.
I do have a domoticz system running, VPN etc so I do not depend on some party receiving the signal, and then the thermostat polling for changes (like Nest/E thermostaat).
/* Edit /*
I also have a RFX 433 option, and thinking about Razpberry
/* End edit /*
But it is an option (if it saves money).
I also have a Cresta TX320 to check the temp (might be moved to the bathroom and install controlled radiator valves later on).
I have ethernet and power at the location of the boiler, so i can install anything there.
Also the termostat is connected with 2 wires at this moment in the living room.
Now I have several options:
Take a subscription with Essent and take the ICY option with it.
Get a Google Nest V3, maybe somewhere cheap.
This means another party gets my precense/heating preference. Not terrible, but if not needed then better not.
Other option:
Get a Remeha iSense from marktplaats. Install this one, and then? Hook a Raspberry to it? (I have one for spare).
Another option:
Get an opentherm gateway, and build a thermostat myself? (Girlfriend wont be liking this option due to startup issues I think, but it is something nice to explore).
I missed an option? What would be best? Also considering future development of Domoticz?
Re: What thermostat to choose..
Posted: Tuesday 05 January 2016 8:39
by JuanUil
You don't need a subscription with Essent for the ICY Thermostat.
I myself have bought one on Marktplaats and it is working perfectly on Domoticz.
I have written a LUA script for controlling it. viewtopic.php?f=38&t=8799
Succes
Jan
Posted: Sunday 10 January 2016 17:22
by solidsjakie
OK, so I got one from Marktplaats.
The previous owner has to de register the thermostat, before I can use it. (So tip for the next one: You can prepare the seller for this)
There is an USB connection om the hub, did you try this to communicate with the hub itself?
*Edit*
Ok, USB is power only I think.
I have downloaded the app for the thermostat, and I configured it as a clock thermostat now, without Essent.
So the Thermostat is programmable without contacting the Internet.
I now went from an On/Off clock thermostat to a modulating clock thermostat, so thats a good thing.
Next up, connecting it to Domoticz.
Im currently portscanning the HUB, it responds to ping, see what else it is doing.
I blocked Internet access for the HUB, so the guy I bought it from cant control my heating (nor Essent can at this moment).
(Its not that I dont trust him, but worst case scenario ;)).
Posted: Monday 11 January 2016 9:55
by solidsjakie
Ok, so I have contacted Essent, and I got reply.
I need to deregister here:
https://mijn.icy.nl/nl/e_thermostat_deregistrations/new
Which costs mee 15 euros. Did you guys have this to?
Posted: Wednesday 20 January 2016 16:39
by Pino112
Can you verify if the Intergas boiler gives a return temperature? I don't know if that is supported by the ICY.
The HRE-boiler isn't listed on the boiler matrix on http://otgw.tclcode.com/matrix.cgi#boilers (HReco and HR are slightly different), so I'm curious if the HRE also does not send the return temperature.
Posted: Saturday 27 February 2016 23:51
by anandus
solidsjakie wrote: [...]
I'm thinking of getting an ICY thermostat from Marktplaats.
But I don't like using some site to control it.
Can I use the thermostat without an internet connection (blocked) and control it directly through Domoticz?
Posted: Sunday 28 February 2016 10:13
by jvdz
anandus wrote: I'm thinking of getting an ICY thermostat from Marktplaats.
Don't think this is possible. The build-in option for ICY is using the Website for controlling the thermostat and I haven't seen anybody figured out a direct connection into/from the ICY.
Jos
Posted: Sunday 28 February 2016 10:34
by anandus
Jos
Ah, thanks for the reply.
Silly that one would need an external site to control a thermostat. But it is what it is.
Posted: Sunday 28 February 2016 10:48
by jvdz
Well, that is a requirement when you advertise that the APP to control the ICY will work from anywhere. ;)
Jos
Posted: Saturday 12 November 2016 0:17
by stormychel
I went another route because I needed 2 thermostats, and all options were rather expensive.. especially for the old rental house we live in.
If you already have a working thermostat, an option is to buy a 433mhz switchable relay (eBay, Aliexpress, ...), and use it to interrupt the control wire to the boiler. That way you can keep the thermostats functionality, and let Domoticz decide when it is actually activated.
Hope this helps someone!
@stormychel
Posted: Saturday 12 November 2016 7:49
by Egregius
And if you use a double relay you can interrupt and override.
One contact in series with the room thermostat, the second contact parallel with it.
Then you have complete control over the thermostat :D
Posted: Saturday 12 November 2016 10:37
by stormychel
Interesting idea!
I ordered 2 more of these relays, one for the living room thermostat and one for "stock", but I might try your idea with 2 of them instead. I am a little worried about a "heater shutdown" command misfiring, leading to the boiler keeping on and room temperature getting very high though... any way to prevent this?
Sending a shutdown command twice for safety might be a solution, but I can't find a way to get this to work in Domoticz...
Posted: Saturday 12 November 2016 12:53
by Egregius
stormychel wrote:Interesting idea!
You're talking about 433mhz device?
With Z-wave you don't need this.
Anyway, sending twice in a script isn't that hard.
In my pass2php script that would be something like:
function heater(){
    global $a,$i;
    sleep(1);
    sw($i['heater'],$a);
Re: What thermostat to choose..issues
Posted: Saturday 12 November 2016 18:09
by stormychel
Yes 433mhz... I had a lot of outlets / remotes laying around and decided to do something useful with it, so no Z-Wave for now. New stuff might be Z-Wave though, we'll see, but I realise it's a better technology.
Thanks for sharing your script!
Posted: Wednesday 07 December 2016 21:21
by MichealLocus
Never knew so much thermostat information
