==== OpenZWave not found, support disabled! on OSX
Posted: Monday 04 January 2016 17:09
by karde
I have successfully setup domoticz under osx and today I got my Aoen Zwave (gen5) stick in the mail :)!
But I'm having some problems with OpenZwave :cry:
Sorry If I'm posting something that has been up before, but spent four hours looking on posts on internet trying to get my aoen wave stick into domoticz but I can't see "OpenZwave" under hardware on my Domoticz server, found out that during ./updatedomo I get the following error:
-- Curl includes found at: /usr/include
-- LIBUSB found at: /usr/local/lib/libusb.dylib
-- ==== OpenZWave not found, support disabled!
I have since then installed open wave with brew
brew install "brew install openzwave" and have the following files under:
//usr/local/lib
libopenzwave-1.2.dylib
libopenzwave.dylib
What am I missing :/? I's the filenames wrong for the dylib files?
Thanks a million for any support!!
Re: ==== OpenZWave not found, support disabled! on OSX
Posted: Monday 04 January 2016 19:54
by karde
Ok, I got it to work, so for anyone else having this problem follow the steps below:
1) Jump to the folder where you have installed domoticz, so for example if it's installed under
"/Users/MYuser/domoticz" go to /Users/MYuser/
2) type this into the terminal
git clone https://github.com/OpenZWave/open-zwave.git
ln -s open-zwave open-zwave-read-only
cd open-zwave
make
cd ..
3) now jump to your domoticz catalog and do a ./updatedomo (need to restart domoticz after this/or computer if you find this easier:))
Now you should se the openzwave under the domoticz webpage / hardware :)
Posted: Friday 18 March 2016 7:31
by trixwood
Hi!
I'm stuck compiling openzwave... to use on osx with domoticz
osx 10.11.2
command line utils 10.11 7.2
installed brew, run brew doctor
then
brew install cmake
brew install boost --with-python
brew install boost-python
brew install libusb
brew install libusb-compat
brew install zlib
brew install openssl
brew link openssl --force
export LDFLAGS=-L/usr/local/opt/openssl/lib
export CPPFLAGS=-I/usr/local/opt/openssl/include
go to ~/Smarthome where i want to install this
cd open-zwave
make
make install
I added the following to manager.cpp in de src dir such that is compiles
#pragma clang diagnostic push
#pragma clang diagnostic ignored "-Wtautological-compare"
(original code)
#pragma clang diagnostic pop
then in ~/Smarthome
git clone https://github.com/domoticz/domoticz.git
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
make
now i am stuck with:
[100%] Linking CXX executable domoticz
Undefined symbols for architecture x86_64:
  "OpenZWave::Manager::RemoveNode(unsigned int)", referenced from:
      COpenZWave::ExcludeDevice(int) in OpenZWave.cpp.o
please help!
Posted: Friday 18 March 2016 8:14
by trixwood
Ow, I also commented out in the /cpp/build/Makefile
#if we are on a Mac, add these flags and libs to the compile and link phases
#ifeq ($(UNAME),Darwin)
CFLAGS	+= -c -DDARWIN -arch i386 -arch x86_64
LDFLAGS += -arch i386 -arch x86_64
LIBS	+= -framework IOKit -framework CoreFoundation -arch i386 -arch x86_64
#else ifeq ($(UNAME),FreeBSD)
#CFLAGS += -I/usr/local/include
#else
#LDFLAGS += -Wl,-soname,libopenzwave.so.$(VERSION)
#LIBS 	+= -ludev
#endif
(and any further references)
but it did not help :/ I would assume it has the right architecture now...
Posted: Friday 18 March 2016 8:15
by trixwood
Makefile of the openzwave lib that is...
Posted: Friday 18 March 2016 8:32
by trixwood
lipo -info libopenzwave.a
Architectures in the fat file: libopenzwave.a are: i386 x86_64
still not good :-/ does anybody have a precompiled domoticz WITH openzwave already installed???
Posted: Friday 18 March 2016 9:20
by trixwood
ok... my bad,
instead of the git of openzwave I used their openzwave-1.4.34.tar.gz download... which works!!! seems i got the 1.2 version first... for some reason...
so no changing anything in the sourcecode or makefiles... just openzwave-1.4.34.tar.gz instead of git clone https://github.com/OpenZWave/open-zwave.git... hope this helps anybody... domoticz 4834...
Posted: Tuesday 19 June 2018 3:39
by gowfer
I just installed Domoticz OS X binary (domoticz_osx_x86_64.tgz). Installed OpenZwave using openzwave-1.4.34.tar.gz(ran make and make install). I still can not see the Aoen Zwave (gen5) stick in the hardware list. I have stopped and restarted domoticz several times but nothing shows up.
Anyone have any suggestions. Thanks
Domoticz V3.8153
OS - El Capitan 10.11.6
OpenZwave - 1.4.34
