[Need advice] Dual switch with power meter
Posted: Monday 04 January 2016 3:25
by dagasoft
Hi.
I need to buy a couple of dual relay switches and I would like to know if there is any that can do power measuring and is compatible with Domoticz. I was thinking about buying Fibaro FGS-221 if I don't find any other, but it would be nice to have power measurement.
The purpose is to actuate 4 1200W radiators, so FGS-221 should work fine as it does 2 x 1500w.
Thanks and regards.
Re: [Need advice] Dual switch with power meter
Posted: Monday 04 January 2016 9:10
by ThinkPad
Qubino has a dual relay module, and as far as i know, all Qubino modules have power measuring (at least the two kinds of Qubino modules i have do).
ZMNHBA2 seems to be the older version (non-Zwave plus), the ZMNHBD1 seems to be the newer Z-Wave Plus version.
But i don't know about the max. load of these, please check for your self.
Posted: Monday 04 January 2016 12:32
by dagasoft
Thanks for your reply, Thinkpad.
Yes, afaik Qubino modules do power measurement, but I need to know if they are fully compatible with Domoticz.
Do the ones you have work fine?
Posted: Monday 04 January 2016 12:56
by IDANIT
Also Philio PAN04 and PAN07 are 2x1500W with Meter. Have them both and no problems.
Posted: Monday 04 January 2016 13:26
by dagasoft
IDANIT wrote:Also Philio PAN04 and PAN07 are 2x1500W with Meter. Have them both and no problems.
Oh, ok. I had read something about Zipato not working fine and I discarded them.
So are they ok? Can you switch relays individually or you have to switch both at the same time?
Thanks.
Posted: Monday 04 January 2016 14:07
by IDANIT
I see 4 devices (one Philio) :o . First switches 1 relay, second switches 2 relay, third switches them both and fourth also switches them both :?: . I delete the third and fourth one cuz I don't need them. But it's up to You and Your needs.
Posted: Monday 04 January 2016 14:20
by dagasoft
Thanks. That behaviour is perfect to me. So what's the difference between PAN04 and PAN07? Both are 2 x 1500w with power measurement?
Posted: Monday 04 January 2016 14:23
by IDANIT
Posted: Monday 04 January 2016 14:33
by dagasoft
Thanks IDANIT. I should go for PAN04, because PAN07 is only 2x1100w
