happy new year everybody and! power usage fluctuating
Posted: Friday 01 January 2016 12:52
Hello everybody,
a happy 2016 from The Netherlands.
let's see if we can make it a better year then 2015
now on topic.
i have noticed that the power usage is not functioning like it should.
i have a Fibaro FGD212 dimmer which functions well
now for the power usage it seems that from time to time the power usage goes to 0 while the light actually is still on.
when you check devices you clearly see the power device using apprix 78 watts and Kwh device is showing a value.
back to the utility tab it shows 0 watt and the Kwh is not running.
anybody has any idea where to look to solve this.
Device showing
80 watt
2 Kwh
utility tab showing
0 watt
2Kwh(and meterr is not advancing)
domoticz version 2.4020 (jumbotroll version)
i can not downgrade to a stable sversion to see if this solves the issue
utility tab showing
0 watt
2Kwh
now on topic.
Device showing
80 watt
2 Kwh
utility tab showing
0 watt
utility tab showing
0 watt
2Kwh
