Nefit Easy™
Posted: Thursday 31 December 2015 1:00
As just mentioned in this thread, viewtopic.php?f=34&t=755&p=66969&hilit=nefit#p66969, Robert Klep has developed a client that can access the Nefit Easy. For more info please go to https://github.com/robertklep/nefit-easy-client and http://gathering.tweakers.net/forum/lis ... 8#45516548
To install the Nefit Easy client on a Pi please follow the below procedure:
The Nefit Client requires Node 4.0 or newer. Problem is the most recent version of wheezy comes with a rather old version of node (think v0.12 or something). The latest stable version of Node is v5.3.0. Install that version by doing this for the Pi 2:
1. node -v
2. wget https://nodejs.org/dist/v5.3.0/node-v5. ... v7l.tar.gz
3. tar -xvf node-v5.3.0-linux-armv7l.tar.gz
4. cd node-v5.3.0-linux-armv7l
5. sudo cp -R * /usr/local/
6. node -v
At step 6 it should show v5.3.0
Then continue with the installation of the Nefit Easy Client.
1. git clone https://github.com/robertklep/nefit-eas ... server.git (if you need to update later on, issue the following: git pull https://github.com/robertklep/nefit-eas ... server.git)
2. cd nefit-easy-http-server
3. sudo npm i nefit-easy-http-server -g
4. export NEFIT_SERIAL_NUMBER= insert your serial number here
5. export NEFIT_ACCESS_KEY= you get the point
6. export NEFIT_PASSWORD= ""
The installation is now done.
After the above I ran an example script which showed the following: Yes succes!
pi@raspberrypi ~/nefit-easy-client $ node example/current-status.js
Temperature is set to 15.0°C, current is 19.9°C.
Outside temperature is 7.0°C.
System pressure is 0.9 bar.
1. node -v
6. node -v
+1
