how to setup old rfxcom usb transmitter&reciever
Posted: Wednesday 30 December 2015 17:17
by nawikre
Hi there,
i want to make the step to completely dump my homeseer system and go for domoticz (on a raspberry), but i have an old rfxcom system. I have a rfxcom transmitter and a seperate rfxcom receiver unit...both on usb. But in domoticz i can only choose usb 433 tranceiver.
If i use my rfxcom transmitter on my raspberry pi usb port and select usb transceiver...it does nothing....i cannot set a mode, it does not read anything.
Does someone have these old units or can help me on how to connect this older system??
many thanks
Iwan
Re: how to setup old rfxcom usb transmitter&reciever
Posted: Wednesday 30 December 2015 22:24
by b_weijenberg
The old USB and RFXLAN are not compatible and will not be added.
Posted: Thursday 31 December 2015 15:48
by nawikre
That is realy crap......
Th en in have tot look for a cheap 433mhz tranciever that works Sith domotica land kaku, as in am gradually switching over tot zwavel...nut all my window screens are stille on kaku
Posted: Friday 01 January 2016 12:24
by Toni
It doesn't matter whether Domoticz supports some hardware or not, for as long as you can somehow support the device through a script. For example I have an old RFXCOM (USB version), and I integrated it into Domoticz this way:
- Added the 'dummy' hardware to Domoticz
- Created devices on the 'dummy' hardware to match my RFXCOM setup (door switches, PIR sensor etc, keyfobs)
- Set up xpl-hub and xpl-rfxcom-rx to receive the data from RFXCOM and publish the data as xPL messages (Domoticz does not understand xPL)
- Created a Perl script using xPL::Client and AnyEvent::MQTT, to convert the xPL messages to MQTT messages, to update the Domoticz devices
I actually also do a similar thing for all of my 1-wire devices. I got so much misread data from temperature sensors that I filter it first, and then send to Domoticz using MQTT.
Posted: Friday 20 January 2017 0:24
by Jeroenvoc
@Toni,
would you like to share a code snippet for the conversion of XPL 2 MQTT messages?
If have a similar setup with an old RFXCom transmitter / receiver and a Gas-counting sensor that I would like to use in domoticz.
Jeroen
Posted: Thursday 17 December 2020 16:29
by wkossen
Toni wrote: Friday 01 January 2016 12:24
having recently inherited an old rfxlan device, is there any chance of still getting this working? I can't find any information on how to achieve this...where do i find xpl-hub and xpl-rfxcom-rx? i know how to get the perl things, but would like some example scripts or specifications to send commands., oh and a pointer on how to send these to the 10001 and 10002 ports of the rfxlan on the network. dinosaur tech, but it should still work...
