Install Domoticz in Centos 7
Posted: Sunday 27 December 2015 11:07
by jokkemokke
After request I will share my guide how to install Domoticz on Centos 7 64 bit.
The guide is based on this post: viewtopic.php?f=17&t=2131 but with a few modifications (Some things from the original guide were not working for me. I think because I use 64 bit Centos and the original guide was based on 32 bit Centos).
1) Download source code:
git clone https://github.com/domoticz/domoticz.git domoticz-code
Domoticz source should now be at /usr/src/domoticz-code
2) Install with yum :
yum install cmake
yum install boost
yum install gcc
yum install libusb
yum install libcurl
yum install gcc-c++
yum install sqlite-devel
yum install boost-devel
yum install zlib-devel
yum install curl-devel
yum install boost-static
yum install libstdc++-static libstdc++-static.i686
3) Copy all boost libraries into /usr/lib/lib
md /usr/lib/lib
cd /usr/lib64/
cp libbost*.* /usr/lib/lib/
4) Modify CMakeLists.txt
Add just after unset(Boost_LIBRARY_DIRS CACHE) :
set(Boost_NO_BOOST_CMAKE ON)
5) Modify smtpclient/SMTPClient.cpp
Comment these lines :
// curl_easy_setopt(curl, CURLOPT_MAIL_FROM, m_From.c_str());
// curl_easy_setopt(curl, CURLOPT_MAIL_RCPT, slist1);
6) Modify main/SQLHelper.cpp
Comment these lignes (two lignes in code) :
// sqlite3_wal_checkpoint(m_dbase, NULL);
7) Cmake
delete CMakeCache.txt
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
8) Make
make
9) Install binaries
cd /usr/src/domoticz
md /usr/local/domoticz
cp domoticz /usr/local/domoticz
cp -r scripts /usr/local/domoticz
cp -r www /usr/local/domoticz
10) Copy domoticz.sh to /etc/init.d
rename domoticz.sh to domoticz
11) Modify /etc/init.d/domoticz
    #! /bin/sh
    ### BEGIN INIT INFO
    # Provides:          domoticz
    # Required-Start:    $network $remote_fs $syslog
    # Required-Stop:     $network $remote_fs $syslog
    # Default-Start:     2 3 4 5
    # Default-Stop:      0 1 6
    # Short-Description: Home Automation System
    # Description:       This daemon will start the Domoticz Home Automation System
    ### END INIT INFO
    # Source function library.
    . /etc/rc.d/init.d/functions
    PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
    DESC="Domoticz Home Automation System"
    NAME=domoticz
    USERNAME=domoticz
    DAEMON=/usr/local/domoticz/$NAME
    #DAEMON_ARGS="-daemon -www 8080 -log /tmp/domoticz.txt"
    #DAEMON_ARGS="-daemon -www 8080 -syslog"
    DAEMON_ARGS="-daemon -www 8080 -log /var/log/domoticz.log"
    STOP_TIMEOUT=10
    pidfile=/var/run/$NAME.pid
    lockfile=/var/lock/subsys/$NAME}
    # Exit if the package is not installed
    [ -x "$DAEMON" ] || exit 0
    # Function that starts the daemon/service
    do_start()
            echo -n $"Starting $NAME : "
            daemon --pidfile=$pidfile $DAEMON $DAEMON_ARGS
            RETVAL=$?
            echo
            [ $RETVAL = 0 ] && touch ${lockfile}
            return $RETVAL
    # Function that stops the daemon/service
    do_stop()
       echo -n $"Stopping $NAME : "
       killproc -p ${pidfile} -d ${STOP_TIMEOUT} $DAEMON
       RETVAL=$?
       echo
       [ $RETVAL = 0 ] && rm -f ${lockfile} ${pidfile}
    case "$1" in
      start)
       do_start
      stop)
            do_stop
      status)
            status -p ${pidfile} DAEMON
       RETVAL=$?
      restart)
            do_stop
            do_start
            echo "Usage: service domoticz {start|stop|status|restart}" >&2
            exit 3
    esac
12) Create user domoticz
useradd domoticks
13) Start service
service domoticz start
14) Test
http://127.0.0.1:8080
Re: Install Domoticz in Centos 7
Posted: Tuesday 05 January 2016 9:52
by kshesq
Hi, i am trying to compile the source (on centos 6.7 x64) according to this page:
but when I run:
I get this message;
CMake Error at CMakeLists.txt:145 (MATH):
math cannot parse the expression: "+2107": syntax error, unexpected
exp_PLUS, expecting exp_OPENPARENT or exp_NUMBER (1)
Can someone help me fix this?
TIA
Kim
Posted: Sunday 17 January 2016 13:05
by marcelr
but when I run:
I get this message;
I bumped into the same issue, still working on it.
The error arises from the previous line in the cmake file:
Gitversion_GET_REVISION(. ProjectRevision)
This renders ProjectRevision empty, so there's nothing to add 2107 to in the next line.
In turn, the Gitversion macro tries to find data in .git, which doesn't exist. This lead to the following error:
fatal: Not a git repository (or any of the parent directories): .git
So, I think the downloaded and extracted zip file does not contain all information required to build properly.
Most likely, some of the build tools on CentOS6 are too old to use for Domoticz. Since I find that quite unacceptable, I will keep trying to get it to work with a bit of patching.
grtz,
marcelr
Posted: Sunday 17 January 2016 17:06
by marcelr
Quick update:
On CentOS6, git is too old, it does not support the option "--count".
I downloaded the git sources for fedora 17, built and installed git (version 2.7.0). This one works, but then you get errors in the boost libraries (missing members). Needs upgrading too.
grtz,
marcelr
Posted: Friday 05 February 2016 0:37
by kshesq
Hi Marcel, yeah you need boost 1.6 http://www.domoticz.com/forum/viewtopic.php?f=6&p=66001
i got domoticz to work on centos 6, just without a version number. i changed the version line to this "MATH(EXPR ProjectRevision "2107")"
now domoticz compiles and the version is 2107 :)
Posted: Friday 26 August 2016 16:46
by Bobbie
I'm Using ClearOS which is based on Centos 7.
I'm also trying to install Domoticz on my server according this page but after the
I got this output and not able to finish the install.
Below the output with errors and Make is not possible. I update Boost already to 1.61
What do I wrong?.
[root@server domoticz]# cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
-- The C compiler identification is GNU 4.8.5
-- The CXX compiler identification is GNU 4.8.5
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Using builtin Mosquitto library
-- Could NOT find OpenSSL, try to set the path to OpenSSL root folder in the system variable OPENSSL_ROOT_DIR (missing: OPENSSL_LIBRARIES OPENSSL_INCLUDE_DIR)
-- Failed to find openssl include files (ssl.h), no TLS support
-- Failed to find the openssl library, no TLS support
-- Compiling Revision #5559
-- Boost version: 1.61.0
-- Found the following Boost libraries:
-- thread
-- date_time
-- system
-- Linking against boost static libraries
-- Found ZLIB: /usr/lib64/libz.so (found version "1.2.7")
-- ZLIB libraries found at: /usr/lib64/libz.so
-- ZLIB includes found at: /usr/include
-- Found CURL: /usr/lib64/libcurl.so (found version "7.29.0")
-- Curl libraries found at: /usr/lib64/libcurl.so
-- Curl includes found at: /usr/include
-- Could NOT find LIBUSB (missing: LIBUSB_LIBRARIES LIBUSB_INCLUDE_DIR)
-- ==== LibUSB not found, support for TE923/Voltcraft disabled!
CMake Error at CMakeLists.txt:478 (message):
Failed to find openssl include files (ssl.h), no HTTPS support
CMake Error at CMakeLists.txt:481 (message):
Failed to find the openssl library, no HTTPS support
-- ==== OpenZWave not found, support disabled!
-- ==== WiringPi include file (wiringPi.h) not found. GPIO support disabled.
-- ==== (Please follow http://wiringpi.com/download-and-install/ if you want to use GPIO.)
-- Not found telldus-core (telldus-core.h), not adding tellstick support
/usr/bin/c++ ;-O3;-DNDEBUG;-I/usr/src/domoticz/main;-I/usr/local/include;-I/usr/include;-I/usr/include;;-DBUILTIN_MQTT -x c++-header -o /usr/src/domoticz/stdafx.h.gch/.c++ /usr/src/domoticz/main/stdafx.h
-- Using static libgcc/libstdc++
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Using unsigned short
-- Check if the system is big endian - little endian
-- Configuring incomplete, errors occurred!
[root@server domoticz]# make
make: *** No targets specified and no makefile found. Stop.
Thanks a lot
B
Posted: Monday 29 August 2016 5:13
by lowgrey
I'm having the same problem on an Intel Atom running Debian 8 Server.
lowgrey@debian:~/domoticz.new$ cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
-- The C compiler identification is GNU 4.9.2
-- The CXX compiler identification is GNU 4.9.2
CMake Error at /usr/share/cmake-3.0/Modules/FindOpenSSL.cmake:293 (list):
list GET given empty list
Call Stack (most recent call first):
MQTT/CMakeLists.txt:13 (find_package)
CMake Error at /usr/share/cmake-3.0/Modules/FindOpenSSL.cmake:294 (list):
CMake Error at /usr/share/cmake-3.0/Modules/FindOpenSSL.cmake:296 (list):
CMake Error at /usr/share/cmake-3.0/Modules/FindOpenSSL.cmake:298 (list):
-- Found OpenSSL: /usr/lib/x86_64-linux-gnu/libssl.so;/usr/lib/x86_64-linux-gnu/libcr
ypto.so (found version ".0.0`")
-- Looking for execinfo.h
-- Looking for execinfo.h - found
-- Compiling Revision #5562
-- thread
-- date_time
-- system
-- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.8")
-- ZLIB libraries found at: /usr/lib/x86_64-linux-gnu/libz.so
-- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.38.0")
-- Curl libraries found at: /usr/lib/x86_64-linux-gnu/libcurl.so
-- Found LIBUSB: /usr/lib/x86_64-linux-gnu/libusb.so
-- LIBUSB found at: /usr/lib/x86_64-linux-gnu/libusb.so
CMakeLists.txt:481 (find_package)
PIO.)
/usr/bin/c++ ;-O3;-DNDEBUG;-I/home/lowgrey/domoticz.new/main;-I/usr/local/include;-I
/usr/include;-I/usr/include;-I/usr/include;;-DBUILTIN_MQTT;-DHAVE_EXECINFO_H;-DWITH_L
IBUSB;-DWWW_ENABLE_SSL -x c++-header -o /home/lowgrey/domoticz.new/stdafx.h.gch/.c++
/home/lowgrey/domoticz.new/main/stdafx.h
See also "/home/lowgrey/domoticz.new/CMakeFiles/CMakeOutput.log".
See also "/home/lowgrey/domoticz.new/CMakeFiles/CMakeError.log".
