Problem with AEOTEC Z-stick gen5 and Fibaro fgd-212 dimmer
Posted: Saturday 26 December 2015 22:30
by gwillems
I use Domoticz version 3.530 on my Raspberry pi 2 witch controls the Z-Stick Gen5 of Aeotec. I am trying to control a Fibaro Dimmer 2 (fgd-212) but failing helplessly.
I have domoticz running manually in debug mode so I see some more logs, these go as follows:
2015-12-26 22:02:35.647 Detail, Node003,   Received: 0x01, 0x09, 0x01, 0x41, 0x53, 0x9c, 0x00, 0x04, 0x20, 0x00, 0x5d
2015-12-26 22:02:35.647 Info, Node003, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2015-12-26 22:02:35.647 Info, Node003,   Protocol Info for Node 3:
2015-12-26 22:02:35.647 Info, Node003,     Listening     = false
2015-12-26 22:02:35.647 Info, Node003,     Frequent      = false
2015-12-26 22:02:35.647 Info, Node003,     Beaming       = true
2015-12-26 22:02:35.648 Info, Node003,     Routing       = true
2015-12-26 22:02:35.648 Info, Node003,     Max Baud Rate = 40000
2015-12-26 22:02:35.648 Info, Node003,     Version       = 4
2015-12-26 22:02:35.648 Info, Node003,     Security      = false
2015-12-26 22:02:35.648 Info, Node003,   Basic device class    (0x04) - Routing Slave
2015-12-26 22:02:35.648 Info, Node003,   No generic or specific device classes defined
2015-12-26 22:02:35.648 Info, Node003,   Mandatory Command Classes for Node 3:
2015-12-26 22:02:35.648 Info, Node003,     COMMAND_CLASS_WAKE_UP
2015-12-26 22:02:35.648 Info, Node003,   Mandatory Command Classes controlled by Node 3:
2015-12-26 22:02:35.648 Info, Node003,     None
2015-12-26 22:02:35.648 Detail, Node156,   Expected reply was received
2015-12-26 22:02:35.649 Detail, Node156,   Message transaction complete
2015-12-26 22:02:35.649 Detail, Node003, Removing current message
2015-12-26 22:02:35.649 Detail, Node003, Notification: NodeProtocolInfo
2015-12-26 22:02:35.649 Detail, Node003, Notification: ValueAdded
2015-12-26 22:02:35.649 Detail, Node003, Query Stage Complete (ProtocolInfo)
2015-12-26 22:02:35.649 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2015-12-26 22:02:35.650 Detail, Node003, QueryStage_Probe
2015-12-26 22:02:35.650 Info, Node003, NoOperation::Set - Routing=true
2015-12-26 22:02:35.650 Detail, Node003, Queuing (NoOp) NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x0f, 0xce
2015-12-26 22:02:35.650 Detail, Node003, Queuing (Query) Query Stage Complete (Probe)
2015-12-26 22:02:35.650 Info, Node003, Sending (NoOp) message (Callback ID=0x0f, Expected Reply=0x13) - NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x0f, 0xce
2015-12-26 22:02:35.662 Detail, Node003,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-12-26 22:02:35.662 Detail, Node003,   ZW_SEND_DATA delivered to Z-Wave stack
2015-12-26 22:02:39.809 Detail, Node003,   Received: 0x01, 0x07, 0x00, 0x13, 0x0f, 0x01, 0x01, 0x9f, 0x7b
2015-12-26 22:02:39.809 Detail, Node003,   ZW_SEND_DATA Request with callback ID 0x0f received (expected 0x0f)
2015-12-26 22:02:39.809 Info, Node003, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2015-12-26 22:02:39.809 Info, Node003,   Node 3 has been marked as asleep
2015-12-26 22:02:39.809 Info, Node003, Node not responding - moving QueryStageComplete command to Wake-Up queue
2015-12-26 22:02:39.810 Detail, Node003, Notification: Notification - NoOperation
2015-12-26 22:02:39.810 Detail, Node003, Notification: Notification - Node Asleep
2015-12-26 22:02:39.810 Detail, Node001, Query Stage Complete (Neighbors)
2015-12-26 22:02:39.810 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2015-12-26 22:02:39.810 Detail, Node001, QueryStage_Session
2015-12-26 22:02:39.810 Detail, Node001, QueryStage_Dynamic
2015-12-26 22:02:39.810 Detail, Node001, QueryStage_Configuration
2015-12-26 22:02:39.810 Detail, Node001, QueryStage_Complete
2015-12-26 22:02:39.810 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2015-12-26 22:02:39.810 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2015-12-26 22:02:39.811 Info,          Node query processing complete except for sleeping nodes.
2015-12-26 22:02:39.811 Detail, Node001, Notification: NodeQueriesComplete
2015-12-26 22:02:39.812 Detail, contrlr, Notification: AwakeNodesQueried
2015-12-26 22:02:39.812  OpenZWave: Awake Nodes queried
2015-12-26 22:09:27.782 Info, Node003, Value::Set - COMMAND_CLASS_WAKE_UP - Wake-up Interval - 0 - 1 - 3000
2015-12-26 22:09:27.782 Detail,
2015-12-26 22:09:27.782 Detail, Node003, Queuing (WakeUp) WakeUpCmd_IntervalSet (Node=3): 0x01, 0x0d, 0x00, 0x13, 0x03, 0x06, 0x84, 0x04, 0x00, 0x0b, 0xb8, 0x01, 0x25, 0x10, 0xe3
2015-12-26 22:09:27.782 Detail, Node003, Queuing (WakeUp) WakeUpCmd_IntervalGet (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x84, 0x05, 0x25, 0x11, 0x51
2015-12-26 22:10:35.017  Error: OpenZWave: Internal Node ValueID not found! NodeID: 3 (0x03), instanceID: 0
2015-12-26 22:11:08.023  Error: OpenZWave: Internal Node ValueID not found! NodeID: 3 (0x03), instanceID: 0
So the most disturbing lines seem (to me) the last ones.
The thing is, when I check the ~/domoticz/Config/fibaro directory i do see: fgd212.xml so that would suggest that he would find the correct config. Can someone help me please?
Re: Problem with AEOTEC Z-stick gen5 and Fibaro fgd-212 dimm
Posted: Sunday 27 December 2015 16:02
by Gravityz
see my other replies in my thread.
you also might want to check if the fgd212 config file is in your config, otherwise you need to upgrade domoticz
/usr/local/domoticz/Config/fibaro should contain a file called fgd212.xml
Posted: Monday 28 December 2015 19:16
by gwillems
Hi Gravityz,
thank you for taking the time to reply. I do seem to have an fgd212.xml file but perhaps there is something wrong with it? This is the md5sum of mine:
5818fc472d55370ace373b42052370b5 fgd212.xml
could you perhaps check if you have the same?
thx.
Posted: Wednesday 30 December 2015 18:34
by rgroothuis
Just installed the FGD212 device. With a push switch the dimmer is working perfectly and I can enable/disable/dimm the lights. Openzwave detects the FGD212 perfectly. The problem is that I cannot enable/disable/dimm the lights from Domoticz. Any idea what the problem could be?
This is the error message I'm getting in the log window:
2015-12-30 18:44:24.034 Error: OpenZWave: Node not found! (NodeID: 4119, 0x1017)
2015-12-30 18:44:28.209 Error: OpenZWave: Node not found! (NodeID: 4119, 0x1017)
2015-12-30 18:44:29.123 Error: OpenZWave: Node not found! (NodeID: 4119, 0x1017)
Which is a bit strange as the node ID in the Openzwave window is 23 (0x17).
Screen Shot 2015-12-30 at 18.48.47.png (52.21 KiB) Viewed 2662 times
I'm using Domitcz Version 3.530 with OpenZWave USB Version: 1.3-523-gb258e9e on an Aeotec Z-Stick Gen5 USB stick.
Posted: Wednesday 30 December 2015 19:00
by rgroothuis
gwillems wrote:Hi Gravityz,
thx.
The default fgd212.xml file I've on the v3.430 of Domoticz has indeed the same hash value as you provided above.
5818fc472d55370ace373b42052370b5 fgd212.xml.original
51561b5717cd815165425575a1dea7bc fgd212.xml
I pulled a new version from Github using the following command:
wget https://raw.githubusercontent.com/xs4/o ... fgd212.xml
And indeed it seems that this file is different, at least it give a different hash value.
I hope that with wget I pull the file in the correct format. Can somebody confirm this is the correct way of pulling a new version of the xml file?
Posted: Wednesday 30 December 2015 19:48
by rgroothuis
Strangely enough, the second dimmer of the same type I just added is working in one go with the xml file I pulled from the github.
Posted: Wednesday 30 December 2015 19:59
by rgroothuis
And I removed the first dimmer from Domoticz and added it again and it is working now.
I changed the "28. Scene activation functionality:" configuration back to "deactivated", maybe this was causing the problem as well.
My problems seems to be solved, hope this can help others as well. Good luck.
Posted: Friday 01 January 2016 14:20
by Gravityz
i noticed that fgd212.xml has a BUG in it.
this is causing wrong settings for a couple of parameters
if you read through the file you see all the parameters go by(1-59)
notice the last line specifies 53 which in fact should be 59.
i am just starting of with Zwave and i can not believe i found that bug since it is so obvious
