Page 1 of 2
[667] Ability to execute script:/// from Blocky
Posted: Saturday 26 December 2015 18:20
by void
tracker.php?p=2&t=667
As asked in viewtopic.php?f=23&t=9489 it would be really nice to be able to run system scripts (bash, python, whatever) from Blocky.
LUA is nice, but putting a sleep in LUA will cause it to run multiple times sequential, which really is a killer for scripts.
A Blocky option 'execute $script after $time' would be a great addition to the Domoticz OS in my opinion.
Cheers.
Re: [667] Ability to execute script:/// from Blocky
Posted: Friday 01 July 2016 15:20
by Ritmeester
+10
Absolute a good idea.
Posted: Wednesday 27 July 2016 16:47
by Muyz
+10
This is indeed a very good suggestion. I have been using Domoticz only for one week and it's exactly what I need.
Posted: Thursday 28 July 2016 4:54
by raym
You could call a script from a dummy switch and then call that switch from blocky.
Posted: Sunday 07 August 2016 13:06
by gizmocuz
Implemented in beta #5437
if you enter an IDX in between {{ and }} , from for example a temperature sensor, it is replaced with the value of this sensor
Hope all is working well....
Posted: Sunday 07 August 2016 13:15
by fransiefrans
Sounds good! I will try this tonight. Thanks
Posted: Sunday 07 August 2016 13:16
by gizmocuz
Forgot to mention... you can find it under the 'messages' section... not sure if it is the logical place, but as open_url was also in here....
Posted: Tuesday 09 August 2016 15:23
by gizmocuz
Is it working ?
Posted: Wednesday 10 August 2016 1:42
by fransiefrans
I'm unable to update to the latest beta version. After 2% it says error internet connection.
Posted: Saturday 13 August 2016 15:00
by bearded
Works great for me. I'm triggering batch files to run in Windows directly from blockly now rather than having to run them from switches. Really useful functionality, thanks! :-)
Posted: Saturday 13 August 2016 23:59
by Muyz
Great! Now I will move from stable to latest greatest :)
Posted: Wednesday 17 August 2016 12:20
by jonazp
I cant seem to run a script within blockly. I get error 32512.
The script works fine when run fron putty or with a switch that calls the script.
Any ideas?
Posted: Friday 19 August 2016 7:12
by bearded
My scripts run batch files (on Windows) which are contained in the 'domoticz' folder and therefore do not need a path specifying. (i.e. just 'tv-on.bat with no / or \ required.) Maybe the problem is when you specify a path in blockly? Try moving a file into your domoticz root folder and executing it as I do. Could be a bug in blockly.
Posted: Friday 26 August 2016 10:49
by jonazp
Cant get it to work
Posted: Sunday 02 October 2016 12:39
by heggink
I noticed that in some cases, starting a script without any parameters results in an error as follows:
Error executing script command (/home/pi/domoticz/scripts/say_ad.sh#). returned: 32512
If I add a space after the script's name then the # is still there but taken as the first parameter of the script (where my script doesn't use any so it works as a workaround).
Anyone else seen this? Obviously only applies to linux( /raspbian).
H
Posted: Tuesday 17 January 2017 10:25
by mikkel75
I see the exact same - I'll try the workaround and report back.... Thanks...
(I'm on x86_64 Ubuntu 16.04)
Posted: Thursday 19 January 2017 12:09
by mikkel75
The space workaround works - but why is there a tailing '#' when the script is called?
Posted: Friday 30 June 2017 12:11
by sjoerd1953
Works great with me. Thanks a lot for this improvement. A few notes:
When Domoticz is running on a Raspberry Pi and you place the bash script in a seperate folder (e.g. /home/pi/domoticz/scripts/bash) then, next to making the script executable with CHMOD 755 you also have to add the folder to your $PATH. You can do this by adding this code to your .profile file and reboot. Use the full directory name as mentioned above.
export PATH=$PATH:directory name
You will find the .profile file in the /home/pi directory as a hidden file. Add the code at the bottom of the file.
I use this to set Milight bulbs to nightlight at sunset. This is the bash code:
#!/bin/bash
echo -n -e "\x33\x00" | nc -u -q 1 192.168.2.25 8899 	# set zone 2 OFF
echo -n -e "\x3A\x00" | nc -u -q 1 192.168.2.25 8899 	# set zone 3 OFF
echo -n -e "\x36\x00" | nc -u -q 1 192.168.2.25 8899 	# set zone 4 OFF
sleep 1
echo -n -e "\xB3\x00" | nc -u -q 1 192.168.2.25 8899 	# set zone 2 NightLight
echo -n -e "\xBA\x00" | nc -u -q 1 192.168.2.25 8899 	# set zone 3 NightLight
echo -n -e "\xB6\x00" | nc -u -q 1 192.168.2.25 8899 	# set zone 4 NightLight
and this the Blockly code:
at sunrise they go out again with:
#!/bin/bash
and this:
Run local batch file Windows
Posted: Thursday 22 February 2018 8:54
by Oxyandy
Hi I have Windows 10
have tried a bunch of different syntax - log says
2018-02-22 18:37:13.940 Executing script: 'C:\_\done.bat '#
But it never fires the batch file
help please
New Bitmap Imtttage (2).jpg (74.18 KiB) Viewed 12496 times
Posted: Tuesday 27 February 2018 20:17
by htilly
Hi! Having the same problem. Did you figure out why there is a tailing # ?!
It's messing up my scripting! =)
mikkel75 wrote: Thursday 19 January 2017 12:09 The space workaround works - but why is there a tailing '#' when the script is called?
