Imperihome
ESFnl
Domoticz version: 2022.2
Imperihome
Post by ESFnl »
As a noob to linux I'm very proud my RPI is running Domiticz! Controlling some cheap switches via RFXcom goes well on the web interface (http://192.168.0.177:8080). I'm able to control the Christmas tree with my tablet! However I'm completely stuck with my next goal: Imperihome.
First I've edited config.yml for my fixed IP:
domo_path: "http://192.168.0.177:3001"
I left MyDomoAtHome.sh untouched because I have the standard Raspberry Pi setup. I tried to run the script:
sh ./run-once.sh
Unfortunately this code is always stuck at the lines
Configuring Plack-Middleware-Auth-Digest-0.05 ... OK
Building and testing Plack-Middleware-Auth-Digest-0.05 ...
I figured out that this code is called at line:
sudo cpanm Task::Plack
within the script. Not having a clue of what this is used for, or how to fix, I've searched many discussions on the forum and Google but don't know my next step.
I would very much appreciate any help but please... in clear simple steps for me to copy/paste into putty ;)
Derik
Re: sh ./run-once.sh
Post by Derik »
ESFnl
Post by ESFnl »
Thank you Derik for your suggestion. However I'm not looking for another frontpage for Domoticz but a way to install https://www.domoticz.com/wiki/ImperiHome.
Derik
Post by Derik »
ESFnl wrote:Thank you Derik for your suggestion. However I'm not looking for another frontpage for Domoticz but a way to install https://www.domoticz.com/wiki/ImperiHome.
You have to pay for the full version of imperihome..
There are better options...
Oke, i cannot help you with Imperihome sorry..
ESFnl
Re: Imperihome
Post by ESFnl »
screendump
screendump
Putty run-once.sh.PNG (30.5 KiB) Viewed 6760 times
<bump> ;)
This is the line
sh ./run-once.sh
is stuck all the time. Any other suggestions?
Abbadon
Re: Imperihome
Post by Abbadon »
how long did you wait? on my rpi2 it take about 30mins to configure so...
ESFnl
Re: Imperihome
Post by ESFnl »
Thank you Abbadon for this suggestion. I believe I've waited longer than that but maybe my patience wasn't enough...
I'll give it a try after work!
mvzut
Imperihome
Post by mvzut »
I think I may be able to help you... In configuration.yml, you shouldn't put port 3001 in the "domo_path" section, but 8080. At least I have it configured that way, and it works perfectly. But at Abbadon says, the run-once.sh script can take quite a long time to run, so give it some time.
By the way, Imperihome (especially the Android version) is still the best and most configurable front end for Domoticz that I have seen so far, don't listen to people that suggest to use alternative frontpages ;-)
ESFnl
Re: Imperihome
Post by ESFnl »
You were right: I wasn't patience enough. The script took 54 minutes! I didn't know it could take that long.
Unfortunately still without success. I ran the script twice. First with the original settings (port 3001) and secondly with port 8080 as mvzut suggested.
Although the script continues and finishes, I believe some errors appear which I don't understand:
pi@raspberrypi ~/domoticz/MyDomoAtHome $ sh ./run-once.sh
Will update packages list first...
Now getting the needed software...
Now getting getting and installing dependencies...
Reading package lists... Done
Building dependency tree
Reading state information... Done
cpanminus is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
--> Working on Task::Plack
Fetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/Task-Plack-0.28.tar.gz ... OK
Configuring Task-Plack-0.28 ... OK
==> Found dependencies: Plack::Middleware::Auth::Digest, Starman, Plack::Middleware::Deflater, Plack::App::Proxy, CGI::PSGI, IO::Handle::Util, FCGI::Client, FCGI, Plack::Middleware::Debug, Plack, Twiggy, Plack::Middleware::ReverseProxy, Net::FastCGI, Corona, Plack::Middleware::Header, PSGI, Starlet, Plack::Middleware::Session
--> Working on Plack::Middleware::Auth::Digest
Fetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/Plack-Middleware-Auth-Digest-0.05.tar.gz ... OK
Building and testing Plack-Middleware-Auth-Digest-0.05 ... FAIL
! Timed out (> 1800s). Use --verbose to retry.
Terminated
! Installing Plack::Middleware::Auth::Digest failed. See /root/.cpanm/work/1452356060.18870/build.log for details. Retry with --force to force install it.
pi@raspberrypi ~/domoticz/MyDomoAtHome $ --> Working on Starman
Fetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/Starman-0.4014.tar.gz ... OK
Configuring Starman-0.4014 ... OK
==> Found dependencies: Net::Server, Test::TCP
--> Working on Net::Server
Fetching http://www.cpan.org/authors/id/R/RH/RHANDOM/Net-Server-2.008.tar.gz ... OK
Configuring Net-Server-2.008 ... OK
Building and testing Net-Server-2.008 ... FAIL
! Installing Net::Server failed. See /root/.cpanm/work/1452356060.18870/build.log for details. Retry with --force to force install it.
--> Working on Test::TCP
Fetching http://www.cpan.org/authors/id/T/TO/TOKUHIROM/Test-TCP-2.14.tar.gz ... OK
Configuring Test-TCP-2.14 ... OK
The Imperihome still cannot connect "Error :( Invalid response from API". Any suggestions?
Imperihome failed to connect.PNG (25.61 KiB) Viewed 6676 times
Heen
Domoticz version: 3530
Re: Imperihome
Post by Heen »
Did you solve your problem?
Raspberry Pi 2 B - Domoticz 3530 - RFXTRX433E - Z-Stick Gen5
ESFnl
Re: Imperihome
Post by ESFnl »
No Heen, unfortunately I still don't know how to solve this issue. In another attempt I've renamed the MyDomoAtHome directory to OLDMyDomoAtHome. Herewith I was hoping to get a clean installtion. However during the run-once.sh I see the following errors:
--> Working on Task::PlackFetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/Task-Plack-0.28.tar.gz ... OK
are::Session
Terminated
pi@raspberrypi ~/domoticz/MyDomoAtHome $ ! Installing Plack::Middleware::Auth::Digest failed. See /r
As always everything goes well untill
Could maybe something goes wrong with this specific version? Did anyone succeed with this installation recently?
epierre
Re: Imperihome
Post by epierre »
So bad you've not come to the official support thread...
in the MDAH repository do a run-once.sh again, I recently fixed a missing dependencies that has effects here.
Also before this command will add the missing.
sudo apt-get install cmake make gcc g++
In fact the procedure install a lot of things, configuration is much shorter ;-) but the remark on port 8080 is very important.
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
ESFnl
Re: Imperihome
Post by ESFnl »
Sorry I didn't know a better place to post my question.
I removed MyDomoAtHome directory to be sure having a new clean download. I changed my domoticz IP address to 192.168.0.176. The script now took over 2 hours (!) where it had four times a >1800 seconds timeout. For example
Building and testing Plack-Middleware-Session-0.30 ... FAIL
The address http://192.168.0.176:8080/json.htm?type ... order=Name nicely shows my scenes and hardware. But http://gateway_ip:gateway_port/devices and Imperihome doesn't work. What would be the gateway with a default installation? What makes the run-once.sh fail?
epierre
Re: Imperihome
Post by epierre »
ESFnl wrote:Sorry I didn't know a better place to post my question.
1st question: if domoticz and the gateway are on the same host you should have in your conf:
- http://127.0.0.1:8080 for domoticz
the gateway_ip:gateway_port would be 192.168.0.176:3001 so you should call http://192.168.0.176:3001/devices if installation is successful
ESFnl
Re: Imperihome
Post by ESFnl »
Would you please copy the right config files as an example? I'm still struggling with the installation. I've formatted my SD-card and re-downloaded the Domoticz image file. After re-installing all the steps unfortunately still no luck.
Now I've got the message:
MyDomoAtHome process is not running... failed!
and
No such process
epierre
Re: Imperihome
Post by epierre »
Try:
./start2.sh
you should see where the error is from.
ESFnl
Re: Imperihome
Post by ESFnl »
Not having a clue what I did... this is the result:
pi@raspberrypi ~ $ cd domoticz/
pi@raspberrypi ~/domoticz $ cd MyDomoAtHome/
pi@raspberrypi ~/domoticz/MyDomoAtHome $ ./start2.sh
YAML Warning: Duplicate map key found. Ignoring.
   Code: YAML_LOAD_WARN_DUPLICATE_KEY
   Line: 17
   Document: 1
 at /usr/share/perl5/YAML/Mo.pm line 24, <$IN> line 1.
        YAML::Mo::__ANON__(YAML::Loader=HASH(0x1b422c8), "YAML_LOAD_WARN_DUPLICATE_KEY") called at /usr/share/perl5/Y                        AML/Loader.pm line 359
        YAML::Loader::_parse_mapping(YAML::Loader=HASH(0x1b422c8), "") called at /usr/share/perl5/YAML/Loader.pm line                         168
        YAML::Loader::_parse_node(YAML::Loader=HASH(0x1b422c8)) called at /usr/share/perl5/YAML/Loader.pm line 103
        YAML::Loader::_parse(YAML::Loader=HASH(0x1b422c8)) called at /usr/share/perl5/YAML/Loader.pm line 25
        YAML::Loader::load(YAML::Loader=HASH(0x1b422c8), "# appdir/environments/development.yml\x{a}# configuration f                        ile fo"...) called at /usr/share/perl5/YAML.pm line 34
        YAML::Load("# appdir/environments/development.yml\x{a}# configuration file fo"...) called at /usr/share/perl5                        /YAML.pm line 75
        YAML::LoadFile("/home/pi/domoticz/MyDomoAtHome/environments/development.yml") called at /usr/share/perl5/Danc                        er/Config.pm line 201
        eval {...} called at /usr/share/perl5/Dancer/Config.pm line 201
        Dancer::Config::load_settings_from_yaml("/home/pi/domoticz/MyDomoAtHome/environments/development.yml") called                         at /usr/share/perl5/Dancer/Config.pm line 182
        Dancer::Config::load("Dancer::Config") called at /usr/share/perl5/Dancer.pm line 258
        Dancer::import("Dancer") called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
        Plack::Sandbox::_2fhome_2fpi_2fdomoticz_2fMyDomoAtHome_2fbin_2fapp_2epl::BEGIN() called at /home/pi/domoticz/                        MyDomoAtHome/bin/app.pl line 19
        eval {...} called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
        require /home/pi/domoticz/MyDomoAtHome/bin/app.pl called at (eval 9) line 3
        eval 'package Plack::Sandbox::_2fhome_2fpi_2fdomoticz_2fMyDomoAtHome_2fbin_2fapp_2epl;
    my $app = do $_file;
    if ( !$app && ( my $error = $@ || $! )) { die $error; }
    $app;
;' called at /usr/local/share/perl/5.14.2/Plack/Util.pm line 120
        Plack::Util::_load_sandbox("/home/pi/domoticz/MyDomoAtHome/bin/app.pl") called at /usr/local/share/perl/5.14.                        2/Plack/Util.pm line 136
        Plack::Util::load_psgi("/home/pi/domoticz/MyDomoAtHome/bin/app.pl") called at /usr/local/share/perl/5.14.2/Pl                        ack/Runner.pm line 179
        Plack::Runner::__ANON__() called at /usr/local/share/perl/5.14.2/Plack/Runner.pm line 24
        Plack::Runner::__ANON__() called at /usr/local/share/perl/5.14.2/Plack/Loader.pm line 55
        Plack::Loader::preload_app(Plack::Loader=HASH(0x13b5288), CODE(0x14aa7e0)) called at /usr/local/share/perl/5.                        14.2/Plack/Runner.pm line 274
        Plack::Runner::run(Plack::Runner=HASH(0x1290a60)) called at /usr/local/bin/plackup line 7
environment:development
log:core
logger:console
domoticz:http://192.168.0.176:8080
[3279]  core @0.000050> PLACK_ENV is set (development) forcing PSGI handler in /usr/share/perl5/Dancer/Handler.pm l.                         31
[3279]  core @0.007378> loading Dancer::Handler::PSGI handler in /usr/share/perl5/Dancer/Handler.pm l. 45
[3279]  core @0.076102> loading handler 'Dancer::Handler::PSGI' in /usr/share/perl5/Dancer.pm l. 464
Use of uninitialized value $opt in lc at /usr/local/share/perl/5.14.2/Starman/Server.pm line 80.
2016/02/13-20:36:49 Starman::Server (type Net::Server::PreFork) starting! pid(3279)
Resolved [*]:3001 to [0.0.0.0]:3001, IPv4
Host [*] resolved to IPv6 address [::] but IO::Socket::INET6->new fails: Address family not supported by protocol at                         /usr/local/share/perl/5.14.2/Net/Server/Proto.pm line 141.
Binding to TCP port 3001 on host 0.0.0.0 with IPv4
2016/02/13-20:36:49 Can't connect to TCP port 3001 on 0.0.0.0 [Address already in use]
  at line 68 in file /usr/local/share/perl/5.14.2/Net/Server/Proto/TCP.pm
2016/02/13-20:36:49 Received QUIT. Running a graceful shutdown
Use of uninitialized value in subtraction (-) at /usr/local/share/perl/5.14.2/Net/Server/PreFork.pm line 356.
Use of uninitialized value in subtraction (-) at /usr/local/share/perl/5.14.2/Net/Server/PreFork.pm line 386.
Use of uninitialized value in subtraction (-) at /usr/local/share/perl/5.14.2/Net/Server/PreFork.pm line 406.
Use of uninitialized value in subtraction (-) at /usr/local/share/perl/5.14.2/Net/Server/PreFork.pm line 414.
2016/02/13-20:36:49 Worker processes cleaned up
2016/02/13-20:36:49 Server closing!
shutdown() on closed socket GEN1 at /usr/lib/perl/5.14/IO/Socket.pm line 294.
epierre
Re: Imperihome
Post by epierre »
@ESFnl something is already runnin on port 3001, try "lsof -i tcp:3001" to find out
ESFnl
Re: Imperihome
Post by ESFnl »
Thank you Epierre for all your patience. You probably noticed I'm not experienced.
A little proud of myself getting your command running!
pi@raspberrypi ~ $ lsof -i tcp:3001
-bash: lsof: command not found
pi@raspberrypi ~ $ sudo lsof -i tcp:3001
sudo: lsof: command not found
pi@raspberrypi ~ $ sudo -v
[sudo] password for pi:
pi@raspberrypi ~ $ cd /
pi@raspberrypi / $ lsof -i tcp:3001
pi@raspberrypi / $ su
Password:
root@raspberrypi:/# lsof -i tcp:3001
root@raspberrypi:/# sudo lsof -i tcp:3001
root@raspberrypi:/# sudo apt-get install lsof
Setting up lsof (4.86+dfsg-1) ...
COMMAND  PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
starman 2133 www-data    5u  IPv4   6021      0t0  TCP *:3001 (LISTEN)
starman 2357 www-data    5u  IPv4   6021      0t0  TCP *:3001 (LISTEN)
starman 2358 www-data    5u  IPv4   6021      0t0  TCP *:3001 (LISTEN)
starman 2359 www-data    5u  IPv4   6021      0t0  TCP *:3001 (LISTEN)
starman 2360 www-data    5u  IPv4   6021      0t0  TCP *:3001 (LISTEN)
root@raspberrypi:/#
What would the next step be? Getting starman another port? Do you know how these conflicts may occur? I am strictly following the instructions on domoticz.com.
epierre
Re: Imperihome
Post by epierre »
it is already running ! so everything is fine there !
