we use a KAKU AMST-606 Draadloos magneetcontact. to switch on and switch of the lights in the garden. ( KAKU AWMD-250 Mini inbouw dimmer multi)
now we use Blocky to do that.
But when the lights allready switched on by hand, and you opend the door the lights dim on and off.
what do we wrong??
Doorswitch turn on / off light
Minimac
- Door sensor.png (33.6 KiB) Viewed 1844 times
- Egregius
- Domoticz version: v2024.7
Re: Doorswitch turn on / off light
Isn't that just because it's a KAKU dimmer? You don't have the status of it in Domoticz.
niclasc
- Domoticz version: 4.10854
Are you sure you should use open/closed? I have a magnet switch on my front door and that is "off" when the door is closed. And if I open the door it sends an "on" signal.
Robert
Why did you set a input in the output statement? You should make your script dependable of the output state. Try the following: when "door contact" is "ON" AND "tuinverlichting" is "OFF" AND time is > sunset AND <sunrise THEN SET "tuinverlichting" ON. Be aware that the sunset sunrise doesn't work well in blockly. See other topic.
