Help wanted updatedevice Yocto-Thermocouple!!
Posted: Thursday 24 December 2015 10:24
by nikels
Hello i am struggling with Lua and updating devices. I both a Thermocouple from yoctopuce I am using this solution of updating devices.
I use the same settings as described in the explanation of Domoticz.
The information the device (Thermocouple) is sending is this.
Request URI: /json.htm?type=command¶m=udevices&script=yoctopuce.lua×tamp=1450868355&network=virtualwindows&THRMCPL1%2d57DD1%23dataLogger=OFF&THRMCPL1%2d57DD1%23temperature2=13%2e46&THRMCPL1%2d57DD1%23temperature1=15%2e03
The Lua sript i am using is this.
local temperature = uri['meteo#temperature1'];
local humidity = uri['meteo#temperature2'];
domoticz_updateDevice(150,151,temperature1 .. ";" .. temperature2 .. ";" .. "0" .. ";" .. pressure .. ";" .. "0");
I am using this script from the manual. The devices IDX is 150 and 151the devices are named temerature1 and temperature2. What am I doing wrong or how do I get this working..some help please.
Re: Help wanted updatedevice Yocto-Thermocouple!!
Posted: Thursday 24 December 2015 10:36
by jvdz
I have not seen a JSON line like that before, are you sure that should be working and starting the LUA script?
The LUA script shown uses some functions which are not in there or are you only showing a part of the script?
Which manual are you referring to that has this example?
Jos
Posted: Thursday 24 December 2015 10:55
by nikels
The manual i am using is this:
https://www.domoticz.com/wiki/Inserting ... ua_parsers
This manual is for the Temperature device am just copied it! Its my first steps in Domoticz
I followed al the steps: Callback : http://<domoticz ip>:<domoticz port>/json.htm?type=command¶m=udevices&script=yoctopuce.lua&
'''yoctopuce.lua''' the name of my script.
I have made two virtual devices Idx 150 temperature1 and two Idx 151 temperature2
I used the ''WWW-Form-UrlEncoded'' setting as descripted in the manual. Together with the script this should also work for the Thermo-couple device that's why i didn't change anything from the settings. Changing it to JSON does not work also.. i think the Lua script only works for the ''WWW-Form'' setting
The meteo-themparate device both have the same software ''VirtualHub'' that creates the ''Outgoing callbacks''
I would like to try the JSON settings but i dont know how to make the Lua script or other script to translate the outgoing callbacks.
I will post the JSON Outgoing callbacks from the ''Virtualhub'' settings.
Posted: Thursday 24 December 2015 11:20
by jvdz
Learned something today as I hadn't encountered this option yet before.
Do you have the domoticz logging enabled and is anything showing up in the log that indicates an error or that the script is ran?
Jos
Posted: Thursday 24 December 2015 12:07
by jvdz
I did a quick test using you total url and created a lua script in lua_parsers,
The Webpage returns a JSON: OK, but the domoticz log shows:
Error: WebServer: /home/pi/domoticz/scripts/lua_parsers/test.lua:1: attempt to index global 'uri' (a nil value)
This would indicate that the uri array is not build at all by domoticz and have no idea why that is.
Same happens when I use the url in the example in the WiKi.
ps:I am using the latest production version.
Jos
Posted: Thursday 24 December 2015 12:52
by nikels
Hello i am getting this as a result! Both my virtual devices nothing shows. the log! tells me the same as your result. Jvdz
Error: WebServer: /usr/local/domoticz/var/scripts/lua_parsers/yoctapuce.la:4: attempt to concatenate global 'pressure' (a nil value)
When i push the ''test'' button i get this result.
''status'' : ''OK'',
''title'' : ''Update Device''
[Connection closed]
Changing the ''Virtualhub '' to JSON i get the same results when i press the ''test'' button. ''OK!!'' But also this results in the same error code in Domoticz log!
Posted: Thursday 24 December 2015 13:59
by jvdz
Looks like you have a different error. I do believe that you have the wrong fieldnames in there.
Your URL contains 2 temperatures with a field name of HRMCPL1-57DD1#temperature1 and HRMCPL1-57DD1#temperature2 so guess it should look something like the below script.
print(#uri)
local temperature1 = uri['THRMCPL1-57DD1#temperature1'];
local temperature2 = uri['THRMCPL1-57DD1#temperature2'];
print(temperature1)
print(temperature2)
print(temperature,humidity)
domoticz_updateDevice(150,0,temperature1 .. ";" .. temperature1);
I also added print(#uri) at he top to check how many entries the array contains for debugging.
Jos
Posted: Thursday 24 December 2015 17:02
by nikels
Hello after a quick test got one reading showing other is also reading but not showing.
2015-12-24 16:45:39.615 WebServer: udevices: 0
2015-12-24 16:45:39.615 WebServer: udevices: 13.02
2015-12-24 16:45:39.616 WebServer: udevices: 11.18
2015-12-24 16:45:39.616 WebServer (updateDevice from LUA) : idx=150 nvalue=151 svalue=11.18;13.02 invalue=151 signallevel=12 batterylevel=255
I used the code provided by jvdz
print(#uri)
print(temperature1)
print(temperature2)
domoticz_updateDevice(150,151,temperature1 .. ";" .. temperature2);]
Temperature 1 = 150
temperature 2 = 151
Its working but just one of the two readings. Temperature 1 is working i am doing something wrong.
Posted: Thursday 24 December 2015 17:13
by jvdz
It makes sense that only one device updates as I think you need to do this for 2 devices when I understand it corectly:
domoticz_updateDevice(150,0,temperature1]
domoticz_updateDevice(151,0,temperature2]
I had put in the extra print() statements to see how many entries you have in the array and the content of the 2 variables. They should show in your logfile and mught want to take them out when it is working.
Jos
Posted: Thursday 24 December 2015 17:46
by nikels
2015-12-24 17:43:54.409 WebServer: udevices: 0
2015-12-24 17:43:54.409 WebServer: udevices: 13.63
2015-12-24 17:43:54.409 WebServer: udevices: 11.38
2015-12-24 17:43:54.409 WebServer (updateDevice from LUA) : idx=150 nvalue=0 svalue=13.63;13.63 invalue=0 signallevel=12 batterylevel=255
2015-12-24 17:43:54.424 WebServer (updateDevice from LUA) : idx=151 nvalue=0 svalue=11.38;13.63 invalue=0 signallevel=12 batterylevel=255
I got this result first result was a error after adjusting your script Jvdz.
I got it working showing above results thanks a lot for the help!
print(#uri)
print(temperature1)
print(temperature2)
domoticz_updateDevice(151,0,temperature2 .. ";" .. temperature2)
