Connecting AWMR-210 to Domoticz
Posted: Monday 21 December 2015 14:11
I've got an AWMR-210 Mini inbouw dimmer (KAKU) but unfortunately I'm not able to connect this to Domoticz (which runs on Raspberry PI2 and RFXtrx433E). I installed the AWMR-210 as per the manual from KAKU and then did a reset. It works when I press the wall switch. However when I push the 'connect button' on the AWMR-210 and try to add the switch to Domoticz it doesn't succeed, nor manually and neither automatically. Manually I used AC as protocol with a unique ID and Unit Code. I really don't know what I'm doing wrong. Maybe the device is broken, however as mentioned the wall switch works as it should.
Is there probably anybody else experiencing the same kind of connection problems with this specific device?
Thanks in anticipation.
