Z-Wave factfile: POPP 123627 wallplug switch
Posted: Saturday 19 December 2015 20:33
by ThinkPad
Supplier:
POPP
Website:
http://www.popp.eu/
Function:
Wall plug switch
Z-Wave+ AKA GEN5
No
Rebranding:
Device Library from http://www.pepper1.net
Can't find anything
Manuals from manuals.zwaveeurope.com and doc.eedomus.com:
http://manuals.zwaveeurope.com/make.php ... POP_123627
Domoticz experience
Hardware:
012 (0x0c)	Unknown	Popp 123601 Plug-in Switch
Remarks:
When turning connected load on/off by hand (pressing button), status of switch in Domoticz is updated without polling which is nice.
Configuration:
Devices
432	Z-Wave	0000C01	1	Switch	Lighting 2	ZWave	On
zwcfg_0xaaaaaaa.xml sample:
	<Node id="12" name="LED-strip TV" location="" basic="4" generic="16" specific="1" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
		<Manufacturer id="0154" name="Popp">
			<Product type="1100" id="0001" name="123601 Plug-in Switch" />
		</Manufacturer>
		<CommandClasses>
			<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" innif="true" mapping="37">
				<Instance index="1" />
			</CommandClass>
			<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="4" innif="true">
				<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
			</CommandClass>
			<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="4" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
					<Item label="Disabled" value="0" />
					<Item label="Off Enabled" value="1" />
					<Item label="On Enabled" value="2" />
					<Item label="On and Off Enabled" value="255" />
				</Value>
			</CommandClass>
			<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
				<Value type="list" genre="config" instance="1" index="1" label="Led mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Help>Set LED indication mode</Help>
					<Item label="Show switch state (Default)" value="1" />
					<Item label="Night mode (inverted switch state)" value="2" />
					<Item label="Operated by Indicator Command Class" value="3" />
				</Value>
				<Value type="short" genre="config" instance="1" index="2" label="Automatically switch off after" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="65535" value="0">
					<Help>If not zero, automatically switch off after a user defined time. Unit: Sec, Min: 0, Max: 65535, Default: 0</Help>
				</Value>
				<Value type="list" genre="config" instance="1" index="3" label="What to do on RF off command" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Help>Defines how to interpret RF Off command. Can be used in conjunction with Auto Off function: Ignore - to switch on the light by motion detectors and switch it off after some amount of time: in case of multiple motion detectors each would try to switch the light off that would break logics; Switch on - to switch on the light on both On and Off paddle press on the remote and switch it off after some amount of time. Button off click will still work (if button operations are not disabled).</Help>
					<Item label="Switch off (Default)" value="0" />
					<Item label="Ignore" value="1" />
					<Item label="Switch on" value="2" />
					<Item label="Switch on if load is off else switch off" value="3" />
				</Value>
				<Value type="list" genre="config" instance="1" index="5" label="Restore switch state after power cycle" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Help>Defines if the switch should restore switch state to the last state prior to device power off (power cycle).</Help>
					<Item label="Yes (Default)" value="1" />
					<Item label="No, turn off" value="0" />
				</Value>
			</CommandClass>
			<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="117" name="COMMAND_CLASS_PROTECTION" version="1" request_flags="4" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Unprotected" value="0" />
					<Item label="Protection by Sequence" value="1" />
					<Item label="No Operation Possible" value="2" />
				</Value>
			</CommandClass>
			<CommandClass id="119" name="COMMAND_CLASS_NODE_NAMING" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
				<Associations num_groups="1">
					<Group index="1" max_associations="1" label="Group 1" auto="true">
						<Node id="1" />
					</Group>
				</Associations>
			</CommandClass>
			<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
				<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6" />
				<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.42" />
				<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.00" />
			</CommandClass>
			<CommandClass id="135" name="COMMAND_CLASS_INDICATOR" version="1" request_flags="4" innif="true">
				<Value type="byte" genre="user" instance="1" index="0" label="Indicator" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
			</CommandClass>
		</CommandClasses>
	</Node>
Conclusion
Works good, also nice that switch status in Domoticz is updated in Domoticz. Also seems to repeate for other nodes. For the price a very good unit!
I (as a NL citizen) bought the BE/FR version (with earthpin), but that doesn't matter. Most of the plugs will fit in, as they already have a hole for the earthpin.
Re: Z-Wave factfile: POPP 123627 wallplug switch
Posted: Saturday 19 December 2015 22:15
by Domosapiens
Can you change the 3001 value in the GUI?
Those high numbers in generally suggest a Command Class version mismatch
(OpenZwave assumes version 1, but the device has a higher version: something for the device specific file)
It looks like the TKB TZ68 (under Wenzhou in the Config directory).
The config file is recently added but with a poor and incomplete, only LED as night light switching in the GUI
http://products.z-wavealliance.org/products/37
Pepper1
http://www.pepper1.net/zwavedb/device/322
(with Russian frequency)
Posted: Saturday 19 December 2015 22:24
by ThinkPad
Domosapiens wrote:It looks like the TKB TZ68 (under Wenzhou in the Config directory).
Looks the same indeed. Popp = rebrand of the TKB? Or the other way round?
Domosapiens wrote:Can you change the 3001 value in the GUI?
Yes, the 3001 setting seems to stick if i change it.
