Pemoticz: Control Domoticz from your Pebble
Posted: Friday 18 December 2015 13:44
by KixAss
I created a small app to control your Domoticz-system from your Pebble watch.
This is a first test-version to control scenes. In the next version it will also be possible to control switches and temperatures.
Url:
https://apps.getpebble.com/applications ... 3b8f000010
Re: Pemoticz: Control Domoticz from your Pebble
Posted: Friday 18 December 2015 14:24
by voorstad
Great idea! Installed it, configured it with both ip and ip:port, but nothing is displayed on the Pebble. Smartphone can connect. Do I miss something?
Posted: Friday 18 December 2015 16:40
by KixAss
Have you entered an internal or external ip-address, and did you include http:// in front and a / after?
Posted: Friday 18 December 2015 20:05
by voorstad
http://192.168.1.110:8080/
Is what I entered. I do not have a user/pw protection.
Pasting The exact same in my browser shows the site.
Posted: Friday 18 December 2015 20:06
by KixAss
Strage, should work. I'll make a better errorhandler and post here when its done.
Posted: Friday 18 December 2015 21:04
by KixAss
Could you try again? First to the settings, then Save and then restart the app.
Posted: Friday 18 December 2015 23:37
by voorstad
No luck.... I rebooted The Pebble even.
Posted: Saturday 19 December 2015 11:06
by KixAss
Just made version 1.1. Could you update and try again?
Posted: Saturday 19 December 2015 23:46
by voorstad
Thanks! But no luck.
Uninstalled it and reinstalled... No change.
When I switch off my wifi, app reads "Error Connecting". With wifi on, nothing appears.
I removed all items but one switch from my dashboard... No change.
Posted: Sunday 20 December 2015 8:34
by KixAss
Have you got any scenes in your installation?
Posted: Sunday 20 December 2015 14:58
by voorstad
That did the trick! Adding a test scene and now all switches are shown!
Posted: Monday 28 December 2015 18:08
by philipgoodfellow
I have installed Pemoticz. I have entered my Domoticz url as:
https://192.168.0.15:443/ (I also tried without the :port)
All I get on the pebble is Error Connecting: 0
All I can think of is you are not supporting https: Am I right?
It is good to see a pebble domoticz app (even if it does not yet work for me).
Philip.
Posted: Tuesday 29 December 2015 13:52
by KixAss
It should work. Are you using an official certificate, or a self-signed?
Posted: Tuesday 29 December 2015 13:57
by goncaloazevedo
Is compatible with time round?
Posted: Tuesday 29 December 2015 15:51
by philipgoodfellow
KixAss wrote:It should work. Are you using an official certificate, or a self-signed?
It is the "self signed" certificate that is installed by the Domoticz installation. It describes itself as "Issued to: Raspberry.local Issued By: Domoticz CA"
Posted: Tuesday 29 December 2015 15:54
by KixAss
Then I think that's the problem. Other problem is that I don't have control over the certificates (which should be accepted and which shouldn't). You could try to add the certificate to your phone, maybe then it will be accepted.
Posted: Thursday 24 March 2016 15:53
by Egregius
Just received my Pebble Time and installed your app. Worked instantly
Maybe a tip: possibility to use a roomplan.
In a roomplan you can select switches, that way it could be a short list on the pebble. Now it's a list of > 50 devices wich is quite huge to browse on such a small screen.
Posted: Thursday 24 March 2016 16:49
by Egregius
Sorry, will use the HTTP Push app.
I need to be able to send update commands for switches that can't be switched...
Posted: Sunday 10 September 2017 9:47
by knielen
Hi KixAss,
this app looks great, but doesn't support the Pebble Time Round yet. Is it much work to make an update?
Verstuurd vanaf mijn XT1562 met Tapatalk
