I'm stuck with My first MySensor
Posted: Thursday 17 December 2015 11:47
by pbrink
After playing around with EasyESP, I'm now diving into the world of MySensor. And very excided about it it. But at this point I'm stuck (in a very final state
). I feel that I'm missing an obious step, but can't find it on the forums and with google
My current setup is;
ESP My Sensor gateway, running successful; verified with a telnet session and also connected with Domiticz log shows successful connect after adding hardware.
Switch sentor; Working correctly, serial output shows transmission and also the gateway receives the command
SEND BY SENSOR
send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
req id
req id
RECEIVED BY GATEWAY
;Gateway startup complete.
255;255;3;0;3;
255;255;3;0;3;
255;255;3;0;3;
Now I can't figure out how I get this switch into domoticz, I've enabled accept new sensors. I even tried Switches -> Learn and than trigger.
If I go to the MySensor Gateway Hardware Settings I see no Nodes, and I can't figure out if I need to add nodes.. Or are they added automatically?
Any help is appreaciated. I feel that I'm very close, but missing the final piece in the puzzle
Re: I'm stuck with My first MySensor
Posted: Thursday 17 December 2015 12:25
by D'rMorris
If your sketch is working on your device, then you should see the device in Setup --> Hardware --> Click on Setup next to the MySensors hardware.
You should see the nodes that reported to the gateway there. Since you do not see it, I would double check the sketch.
I have also one issue with a MySensors sensor: all my sensors appear in the hardware section (and also in the unused devices under Setup --> Devices --> Not used) except for 1 sensor.
I see it in hardware, but a device is never added. I expect that the sensor does not send the data correctly. The sensor is only added from the first successful data transfer onwards.
So, if you connected a wire incorrect to the Arduino board, the sensor will report itself to Domoticz (you can see it in hardware), but a device is never added.
Posted: Thursday 17 December 2015 12:53
by pbrink
@D'rMorris, thanks for the reply.
The sketch is fine, It's a clear copy of the switch/button/window sensor code.
I did notice something strange, the wifigateway reboots after connecting Domoticz to it. This is what I did;
1. Connect with telnet session to gateway
2. Verify that when I trigger the sensor the gateway receives the transmission (see code in start topic).
3. Remove hardware; Mysensor LAN interface in domoticz
4. Add hardware; Mysensor LAN interface in domoticz
After step 4 (adding the hardware) the gateway startup is again initiated and the telnet session is lost.
0;3;0;14;Gateway startup complete.
In Domoticz log I can see the following information
2015-12-17 12:49:20.542 MySensors: trying to connect to: 192.168.0.113:5003
2015-12-17 12:49:21.545 MySensors: connected to: 192.168.0.113:5003
Is this normal behavior? It is weird because also after a reboot of domoticz the gateway restarts. This might be the reason that Domoticz doesn't see any nodes, because there is no connection.
Does Domoticz write something in the log file if the connection to the LAN gateway is lost?
Posted: Thursday 17 December 2015 13:40
by D'rMorris
Good question about the log. I only have experience with the serial gateway variant, not the LAN one. You do not have a serial gateway variant laying around?
They're very cheap at aliexpress, so you could build a serial gateway and test with that to rule out the sketch?
Posted: Thursday 17 December 2015 14:10
by pbrink
Yes, I just build a USB serial gateway and everything works fine than. Atleast I know that the issue is in the wireless gateway.
Still this issue might be Domoticz related. I can connect with multiple telnet sessions to the gateway without the restart, but as soon as Domoticz connects I lose the connection to the gateway.
There is another difference between the serial and the lan gateway. If I look at Domoticz harware I can see the mySensor version number for the USB gateway the LAN gateway shows '?' .
Anyone here that uses the Wireless Gateway with domoticz?
Posted: Thursday 17 December 2015 19:11
by gizmocuz
I had the serial gateway for a long time -> working
now i loaded the mysensors.org ethernet gateway in an arduino mega with the WS5100, running for over a month also ok
no experience with espEasy, only with real arduino's
Looking at your first log, it seems there is no line ending (\n) only a line feed (\r), maybe this is a problem?
Ps. using mysensors 1.6 at the moment
Posted: Friday 18 December 2015 12:09
by pbrink
Oke, I'll keep using the serial for know.. The downside of that my sensors on the attic are out of reach.
I don't think this problem is Domoticz related, I've found others that have simulair problems. I'll wait till a new version of MySensor.
http://forum.mysensors.org/topic/2328/e ... connects/8
I'm still using version 1.5, this issue might be fixed with 1.6. But for know I'm so new to MySensor that I rather spend my time building and testing some sensors, I'll upgrade to 1.6 after I finalize some sensors (and know what sensors I want to build).
Thanks for all the advice (and for Domoticz, it's truly a great domotica platform
