Open zwave
Posted: Monday 14 December 2015 20:56
by Rena
I have installed the Domoticz Rasp Image from the homepage.
Do I have to install and complie Open Zwave if I want to use an Aeon Lab stick or is open zwave included in the image?
Re: Open zwave
Posted: Tuesday 15 December 2015 8:39
by gizmocuz
its included in the image (actually it is static linked in domoticz)
Re: Open zwave
Posted: Tuesday 15 December 2015 9:38
by Rena
gizmocuz wrote:its included in the image (actually it is static linked in domoticz)
Thanks! So I just have to power off the Rasp and put the stick in an USB-port. Then start up and add hardware?
Re: Open zwave
Posted: Tuesday 15 December 2015 14:39
by gizmocuz
Yep
Re: Open zwave
Posted: Tuesday 15 December 2015 19:10
by Rena
gizmocuz wrote:Yep
Doesn´t work on my Rasp. I think I need some help.
When trying to see if the Rasp have found the stick, it looks like this. I can see two things attached to USB-ports and that´s correct. I have the RFXTRX and Aeon stick attached.
When trying to add the stick under hardware, the only USB-port I have is the which is connected to the RFXTRX.
What should I do?
Re: Open zwave
Posted: Wednesday 16 December 2015 8:11
by Rena
Now I also have "ttyACM0"-port. Should I use one of these or try to change to ttyusbxx?
Re: Open zwave
Posted: Wednesday 16 December 2015 10:02
by radem205
Re: Open zwave
Posted: Wednesday 16 December 2015 10:19
by Rena
Thanks - just one question. I have both "TTYAMA0" and "TTYACM0". Is there any way to check which one is Aeon stick?
