Cannot connect to Marmitek SC9000
Posted: Sunday 13 December 2015 11:01
by peckerdunne
I can't arm or disarm my SC9000 alarm console with Domoticz. Using RFXmgr on my Windows 10 machine with my RFXcom 433E, I can arm or disarm the console without a problem.
I just got my RFXcom on Friday so I'm a new boy and probably missing something fundamental and blindingly obvious.
Any assistance gratefully received
Re: Cannot connect to Marmitek SC9000
Posted: Sunday 13 December 2015 16:29
by gizmocuz
Hello Pecker,
I am working on the issue.
If it's correct, you have a small x10 remote (kfob) unit, this can also be received by domoticz (do not forget to enable 'accept new hardware devices' in the domoticz settings)
if you add this kfob to domoticz from the devices tab, (or learn command), you should be able to arm/disarm your system
What i would like todo, is in the main settings page (next to the security panel alarm code), add the option to add the ID (3 bytes) of your (or ... a ...) kfob,
and when you arm/disarm the domoticz security panel, it will send the X10 RF command to automatically transmit the remote code, and this would set your sc9000 alarm state
Can you confirm you have such a remote/kfob ? Or did you learn such a remote from the RFXMngr application ?
Posted: Monday 14 December 2015 14:43
by peckerdunne
Thanks Gizmocuz.
I think I did that but I reckon I'll delete the devices and start again this evening. I'll update you on the results.
Posted: Monday 14 December 2015 22:22
by peckerdunne
I deleted the keyfob and added it again using the add newhardware and learn options but the security panel still does not connect to the SC9000. I'm not sure how to add the code manually.
However I was able to connect my SH624 remote to the SC9000 so I can use that.
Posted: Tuesday 15 December 2015 8:17
by gizmocuz
At the moment there is no link to the security panel and the SC9000, this was something that 'could' be made
does this mean you can use the remote in domoticz to arm/disarm the sc9000 now ?
Posted: Tuesday 15 December 2015 14:35
by peckerdunne
Yes, I was able to pair the SH624 remote with RFXcom to arm/disarm the SC9000 using Domoticz.
Good enough for now; lots more learning and stuff to do. Thanks for your help.
