Page 1 of 5
Different Backups from Crontab to network
Posted: Saturday 16 November 2013 9:17
by Derik
The search came to nothing .....
I 'm getting deeper into crontab .
And there i found what I'm looking for an automatic backup function .
Have found the document , copy and paste from the wiki I manage just yet . :D
What I would like is that the backup is written to a hdd in the network .
I have 3 RPi with domoticz , it seems to me something to put them , all 3 in1 folder each with its own name . This seems safer , since I still have a power failure , and that the RPi hate , is my experience . :? :?
Can anyone help me. ?
The location of the folder : 192.168.0.11 \ ET9X00 \ Hard Disk \ Domoticz backup
This hdd is always on , but in the sleep function , is that a problem?
If I only :
0 4 *** sudo ~ / domoticz / scripts / domoticz_backup.sh
Use the crontab, put the backup on the sd of the RPI , and my question is.
What should I put in the cron to place the backup to a network location
And what can I change the cron to backup the files as backup1, 2 and 3. [ from the 3 different RPi ]
Thank you . !
Edit ..
Now when I look good, I see the file ~ / domoticz / scripts / domoticz_backup.sh
Not in that folder ?
Do I have to create that file ?
And what have to be in that file?
[solved]
Re: Different Backups from Crontab to network
Posted: Saturday 16 November 2013 11:07
by Keptenkurk
Hi Derik,
I see you got the cron example from the Wiki but indeed the domoticz_backup.sh script does not come with the Domoticz installation.
First you need to know which protocol(s) your network disk supports to write to. In my case i choose to use FTP and i suspect most Network drives will support that.
The script is taken from this thread here or this one on the old forum (yes apart from the manual, forum and Wiki there is also an old forum with lots of info).
Leonardo's script lets you choose how to send your backup, by mail, FTP even upload to dropbox is possible. You can take out the things you need for your purpose. I tried to do that and use as much info you gave as possible. Please change your Domoticz IP and FTP username/password and the target directory to your situation!
#!/bin/bash
# LOCAL/FTP/SCP/MAIL PARAMETERS
SERVER="192.168.0.11"   		# IP of Network disk, used for: ftp mail scp
USERNAME="ftpuser"			# FTP username of Network disk used for: ftp mail scp
PASSWORD="ftppassw"	         	# FTP password of Network disk used for: ftp mail scp
DESTDIR="/opt/backup"		# used for: local
DOMO_IP="192.168.1.199"		# Domoticz IP used for all
DOMO_PORT="8080"			# Domoticz port used for all
### END OF USER CONFIGURABLE PARAMETERS
TIMESTAMP=`/bin/date +%Y%m%d%H%M%S`
BACKUPFILE="domoticz_$TIMESTAMP.db"
BACKUPFILEGZ="$BACKUPFILE".gz
### Create backup and ZIP it
/usr/bin/curl -s http://$DOMO_IP:$DOMO_PORT/backupdatabase.php > /tmp/$BACKUPFILE
gzip -9 /tmp/$BACKUPFILE
### Send to Network disk through FTP
curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/ET9X00/Hard Disk/Domoticz_backup/"
### Remove temp backup file
/bin/rm /tmp/$BACKUPFILEGZ
### Done!
Just save it in the scripts folder as domoticz_backup.sh, make it executable by
sudo chmod 777 /home/pi/domoticz/scripts/domoticz_backup.sh
and try to start it from the commandline in the scripts directory with
./domoticz_backup.sh
and fix the errors :x until your're :P
Then the cron will do it every night at 04:00 for you.
You can run this on each of your PI's
PM me if you need more help...
Meanwhile i have some scripts seen passing by which even backup the whole SD card but i did not yet try that...
/paul
Posted: Saturday 16 November 2013 19:22
by Derik
root@raspberrypi:~# cd home/pi/domoticz/scripts
-bash: cd: home/pi/domoticz/scripts: Bestand of map bestaat niet
root@raspberrypi:~# cd /home/pi/domoticz/scripts
root@raspberrypi:/home/pi/domoticz/scripts# ./domoticz_backup.sh
./domoticz_backup.sh: regel 9: $'\r': opdracht niet gevonden
./domoticz_backup.sh: regel 11: $'\r': opdracht niet gevonden
./domoticz_backup.sh: regel 15: $'\r': opdracht niet gevonden
./domoticz_backup.sh: regel 19: $'\r': opdracht niet gevonden
'!zl: Can't open '/tmp/domoticz_20131116190802
curl: try 'curl --help' or 'curl --manual' for more information
./domoticz_backup.sh: regel 22: $'\r': opdracht niet gevonden
/bin/rm: kan '/tmp/domoticz_20131116190802\r.db\r.gz\r\r' niet verwijderen: Bestand of map bestaat niet
./domoticz_backup.sh: regel 25: $'\r': opdracht niet gevonden
Second try
* About to connect() to 192.168.0.10 port 21 (#0)
*   Trying 192.168.0.10...
* connected
* Connected to 192.168.0.10 (192.168.0.10) port 21 (#0)
* FTP 0x10acff8 state change from STOP to WAIT220
< 220 Welcome to the openpli FTP service!
> USER ftpuser
* FTP 0x10acff8 state change from WAIT220 to USER
< 331 Please specify the password.
> PASS ftppassw
* FTP 0x10acff8 state change from USER to PASS
< 530 Login incorrect.
* Access denied: 530
* Closing connection #0
Third time:
* connected
* FTP 0x652ff0 state change from STOP to WAIT220
> USER root
* FTP 0x652ff0 state change from WAIT220 to USER
> PASS root
* FTP 0x652ff0 state change from USER to PASS
< 230 Login successful.
> PWD
* FTP 0x652ff0 state change from PASS to PWD
< 257 "/"
* Entry path is '/'
* FTP 0x652ff0 state change from PWD to STOP
* protocol connect phase DONE
* DO phase starts
> CWD ET9X00
* FTP 0x652ff0 state change from STOP to CWD
< 550 Failed to change directory.
* Server denied you to change to the given directory
* DO phase is complete
* Uploaded unaligned file size (0 out of 41287 bytes)
* Connection #0 to host 192.168.0.10 left intact
> QUIT
* FTP 0x652ff0 state change from CWD to QUIT
< 221 Goodbye.
* FTP 0x652ff0 state change from QUIT to STOP
root@raspberrypi:/home/pi/domoticz/scripts# r
Blank password:
root@raspberrypi:/home/pi/domoticz/scripts# ^C
* connected
* FTP 0x1fbdff0 state change from STOP to WAIT220
> USER
* FTP 0x1fbdff0 state change from WAIT220 to USER
> PASS
* FTP 0x1fbdff0 state change from USER to PASS
< 503 Login with USER first.
* Access denied: 503
It seems there already?
Blank lines removed?
Password, but that is not really in?
Is there a way that I can do a test
The file system is ext3 HHD, maybe some of you out there?
Actually there is no hdd password and user.
Only when i left the field blank in the. Sh he asks for a use
thanks
Posted: Saturday 16 November 2013 23:30
by Keptenkurk
Derik,
You're progressing! Still a bit :x but close to :P
The trird try came closest! I'll explain what the feedback is.
* connected
-----> Great! Your Networked disk supports FTP
> USER root
> PASS root
-----> And the script manages to login! Keep this username & password in your script
> PWD
< 257 "/"
* Entry path is '/'
* DO phase starts
-----> PWD stands for Print Working Directory. i.e. In what directory are we currently? The answer is: / the root.
> CWD ET9X00
-----> CWD means Change Working Directory to ET9X00, but this fails probably because it doesn't exist!
> QUIT
< 221 Goodbye.
-----> no more to do, so quit.
Now in your previous post you mention the target folder is 192.168.0.11 \ ET9X00 \ Hard Disk \ Domoticz backup
Appearantly ET9X00 is the device? If so you mean that the folder "Domoticz backup" is in the root?
Having spaces is a bad idea so change it to Domoticz_backup and assuming it is in the root like /Domoticz_backup change the script to:
curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/Domoticz_backup/"
Watch the script output if the CWD works out and the backup file is transferred.
/paul
Posted: Sunday 17 November 2013 2:19
by Derik
Ai ...
The proposals that you gave nie help at all.
But is he really be in the root?
I modified it now, it looks like I should go ...? Through PLi
But also seems not well ...
Firts change, all space gone
* connected
* FTP 0x4a7ff0 state change from STOP to WAIT220
> USER root
* FTP 0x4a7ff0 state change from WAIT220 to USER
> PASS root
* FTP 0x4a7ff0 state change from USER to PASS
> PWD
* FTP 0x4a7ff0 state change from PASS to PWD
< 257 "/"
* Entry path is '/'
* FTP 0x4a7ff0 state change from PWD to STOP
* DO phase starts
> CWD ET9X00
* FTP 0x4a7ff0 state change from STOP to CWD
* Uploaded unaligned file size (0 out of 43930 bytes)
> QUIT
* FTP 0x4a7ff0 state change from CWD to QUIT
< 221 Goodbye.
* FTP 0x4a7ff0 state change from QUIT to STOP
Second try it from the root of PLi
* connected
* FTP 0xa7bfd0 state change from STOP to WAIT220
> USER root
* FTP 0xa7bfd0 state change from WAIT220 to USER
> PASS root
* FTP 0xa7bfd0 state change from USER to PASS
> PWD
* FTP 0xa7bfd0 state change from PASS to PWD
< 257 "/"
* Entry path is '/'
* FTP 0xa7bfd0 state change from PWD to STOP
* DO phase starts
> CWD ET9X00
* FTP 0xa7bfd0 state change from STOP to CWD
* Uploaded unaligned file size (0 out of 44006 bytes)
> QUIT
* FTP 0xa7bfd0 state change from CWD to QUIT
< 221 Goodbye.
* FTP 0xa7bfd0 state change from QUIT to STOP
Posted: Sunday 17 November 2013 6:08
by asjmcguire
CWD ET9X00
Means the directory doesn't exist - and it doesn't you have shown that - ET9X00 is the name of the device - not the name of a directory.
Your first step is to use a program like Filezilla available free from many download sites, ftp onto your NAS from filezilla using the same credentials as the script uses to "see" what folders are in actually in the initial path "/" It is likely that the ftp daemon running on the NAS dumps you inside the Windows share called "Harddisk" - however it may be dumping you in the share called "Root".
Figure out what folders are visible via ftp and then adjust the script accordingly.
Just for info - it is likely that this line:
will become something more like
Posted: Sunday 17 November 2013 7:27
by antwan
The device is not a Nas, but a Linux stb (extrend et-9000).
Posted: Sunday 17 November 2013 9:45
by Derik
And it's true it's a satellite box, with Open PLi.
How beautiful zoi it be if these two could work together. ;) ;)
I have somethings changed.... [ looks better ] :D :D
root@raspberrypi:/home/pi/domoticz/scripts# ./domoticz_backup.sh        * About to connect() to 192.168.0.10 port 21 (#0)
* connected
* FTP 0x3aff58 state change from STOP to WAIT220
> USER root
* FTP 0x3aff58 state change from WAIT220 to USER
> PASS root
* FTP 0x3aff58 state change from USER to PASS
> PWD
* FTP 0x3aff58 state change from PASS to PWD
< 257 "/"
* Entry path is '/'
* FTP 0x3aff58 state change from PWD to STOP
* DO phase starts
> CWD media
* FTP 0x3aff58 state change from STOP to CWD
< 250 Directory successfully changed.
> CWD hdd
> PASV
* FTP 0x3aff58 state change from CWD to PASV
* Connect data stream passively
< 227 Entering Passive Mode (192,168,0,10,219,70).
* connected
* Connecting to 192.168.0.10 (192.168.0.10) port 56134
* FTP 0x3aff58 state change from PASV to STOP
> TYPE I
* FTP 0x3aff58 state change from STOP to STOR_TYPE
< 200 Switching to Binary mode.
> STOR Domoticz_backup
* FTP 0x3aff58 state change from STOR_TYPE to STOR
< 553 Could not create file.
* Failed FTP upload: 553
* DO-MORE phase ends with 25
* Remembering we are in dir "media/hdd/"
* Uploaded unaligned file size (0 out of 44080 bytes)
> QUIT
* FTP 0x3aff58 state change from STOR to QUIT
< 221 Goodbye.
* FTP 0x3aff58 state change from QUIT to STOP
This one is the problem i gues?? = < 553 Could not create file.
And this one is very strange: * Remembering we are in dir "media/hdd/"
Because: curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/media/hdd/Domoticz_backup"
What is the file what should come to be?
I would first have to put down first ...
Posted: Sunday 17 November 2013 10:58
by Keptenkurk
Derik,
You're just a "/" away from :P '
Change
into
curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/media/hdd/Domoticz_backup/"
Thanks for adding the info, that sure helps helping.
/Paul
Posted: Sunday 17 November 2013 11:08
by Derik
GREAT!!!!!
THANKS!!
You can hear him turn on the HDD, please wait and he finished! Says
No nas device, and still a nightly backup.
Bizarre!
But, now comes the dummy question again.
I now see a xxxxx.DB.GZ file.
While I had expected. Only. Db
What should I do with this file as a backup to put back?
edit:
And how can I automatically give different names to the different backups
Edit2:
dummy dumb ..
gz is a zip so unzip.
Name change to domticz.db
And then restore that I manage certain
Remains the last over.
3x domoticz, xxxx.backup xxxxx.backup 1 and 2 and 3 xxxx.backup
That's what I love to see in the folder on hdd
Posted: Sunday 17 November 2013 11:29
by Keptenkurk
Derek,
Great to see it works.
The database is archived (zipped). For instance WinRAR is able to unzip, but there are more tools out there. This will give you a file like Domotiz_20131117110117.db.
In case disaster strikes rename it to domoticz.db, stop domoticz, overwrite the database (all info in contained in domoticz.db) and start domoticz again.
Maybe the easiest way to have multiple backups is by creating a separate folder for each one of them on the STB and have the script write in their "own" folder...
/paul
Posted: Sunday 17 November 2013 11:42
by Derik
I feel good!!
It works ... :D :D :mrgreen: :mrgreen: :mrgreen:
Domoticz 3 per backup ...
I'm a pro at the be ..
Now wait if he does his work tonight ..
Every backup but just give another time, otherwise the pressure on the hdd.
And then there should be a lock on this topic... :D :D :roll: .
Or if there are more people with questions, I can help, mwhaaaa [who would have expected] ;) ;)
Thanks!!
Posted: Sunday 17 November 2013 15:42
by Keptenkurk
Haha you make my day!
Posted: Sunday 17 November 2013 16:01
by Derik
Keptenkurk wrote:Haha you make my day!
No you did...
xxxx
Posted: Monday 18 November 2013 20:45
by Derik
And watch...
Posted: Friday 22 November 2013 7:19
by Derik
I have a problem ....
Sind I tried the crontab to fine tune. [ make crontab on a other hour. ]
I do not get it together to get the backup. Working
've Tried several.
Even all the steps done over again.
Should I make the crontab as root or pi?
The command i used:
This is working ine:
Where would could i go wrong?
I was so proud .... :( :( :(
Posted: Friday 22 November 2013 8:32
by Keptenkurk
Well... since it *did* work the problem should be in the crontab... what does the file look like after your change. Did you only change the number 4 ?
/paul
Posted: Friday 22 November 2013 17:25
by Paulyoh
Will this URL help?
How to configure crontab:
http://v1.corenominal.org/howto-setup-a-crontab-file/
Posted: Friday 22 November 2013 22:19
by Derik
Thanks..
pfff.
It should all be correct though in linux:
0 4 * * * sudo ~ /domoticz/scripts/domoticz_backup.sh
Should be:
0 4 * * * sudo ~/domoticz/scripts/domoticz_backup.sh
So a space after ~ he hates ..
Mierenneukers .... :D :D :D
But yeah learned a lot ...
pay attention
And I know right away that copy and paste causes a problem ..
Posted: Saturday 23 November 2013 10:43
by Derik
proud ... :D
I wish they would have ....
Thanks :mrgreen:
