Error messages in log : ... thread seems to have ended unexp
Posted: Thursday 10 December 2015 23:08
by McSoda
Hi All,
Since this evening, I have some strange messages in the domoticz log :
2015-12-10 22:57:04.042 Error: EventSystem thread seems to have ended unexpectedly
2015-12-10 22:57:04.042 Error: Scheduler thread seems to have ended unexpectedly
2015-12-10 22:57:04.042 Error: Motherboard hardware (1) thread seems to have ended unexpectedly
Additionnally, GUI freezes often, I have to wait for seconds to switch from tab to tab (for example to pass from #/log to #/dashboard).
Chrome error screenshot
I haven't a lot of devices, just
* a teleinfo device,
* z-wave network with Aeotec Z-Stick S2 controller and 8 devices.
and 2 events.
Regards,
Re: Error messages in log : ... thread seems to have ended u
Posted: Friday 11 December 2015 15:14
by rbeumer
Same issue here. Running latest stable version on a Raspberry Pi2.
Please advise
Posted: Friday 11 December 2015 20:34
by SevenW
.. and for me as well. It occurs after 1-1.5 days of operation.
SevenW
Posted: Friday 11 December 2015 20:39
by amdavies78
I been having the same issue with my pi running the zwave domoticz server, my other 1 isn't have any issues which only has the piface board isn't having any issues. Only been happening since the latest update.
Posted: Friday 11 December 2015 21:12
by SevenW
On another thread with a similar issue a saw two suggestions.
1. out of memory: check with df -h on command line if a mount is full (not the case with me)
2. Two MQTT brokers in the hardware list. -> delete one.
I happened two have two brokers, listening to different MQTT servers, but I now deleted one to see whether it becomes stable.
SevenW
Posted: Friday 11 December 2015 22:35
by McSoda
No more troubles anymore. They disappeared.
May be linked to a faulty disk which slowed down my Syno ? :-/
Thanks,
Posted: Saturday 12 December 2015 21:04
by rbeumer
none of the 2 above options applies to me. None of my mounts is full and I have no MQTT brokers in the hardware listed at all.
Posted: Monday 14 December 2015 19:41
by SevenW
No, going back to one MQTT broker did not solve it. Next hang-up after 48 hours. This makes it pretty unworkable.
Maybe GizMoCuz can advise?
SevenW
Re: Error messages in log : ... thread seems to have ended unexp
Posted: Sunday 28 February 2016 9:38
by amdavies78
I recently redone some changed, I've found if I used the pi with the zwave controller to run the script to turn off my lights I don't get the error/crash, but if I run the same script from my master.it give the error/crashes. Turning the lights on from the master doesn't cause any issues.
Posted: Saturday 10 December 2016 10:21
by Minglarn
Hi!
Now my instande of Domoticz acts like this.
Every hour it spits out this in the log: EventSystem thread seems to have ended unexpectedly
2016-12-09 18:02:23.727 Error: EventSystem thread seems to have ended unexpectedly
2016-12-09 19:02:08.517 Error: EventSystem thread seems to have ended unexpectedly
2016-12-09 21:02:18.358 Error: EventSystem thread seems to have ended unexpectedly
 2016-12-09 23:02:04.875 Error: EventSystem thread seems to have ended unexpectedly
2016-12-09 23:02:04.875 Error: Scheduler thread seems to have ended unexpectedly
 2016-12-10 00:04:16.783 Error: EventSystem thread seems to have ended unexpectedly
2016-12-10 00:04:16.783 Error: Scheduler thread seems to have ended unexpectedly
2016-12-10 02:01:58.678 Error: EventSystem thread seems to have ended unexpectedly
 2016-12-10 08:02:03.316 Error: EventSystem thread seems to have ended unexpectedly
2016-12-10 08:02:03.316 Error: Scheduler thread seems to have ended unexpectedly
And this keeps going on for every hour... Anyone who could help me solve this or give me some tip?
Latest beta installed... on RPI2.
Posted: Tuesday 31 January 2017 9:58
by Flopp
Minglarn wrote:Hi!
It can be something that runs every hour.
Try to disable all your Events and see it that helps. It can also be the backup function which runs every hour.
Posted: Tuesday 31 January 2017 11:48
by Minglarn
Tried that ...
And the solution was to stop BACKUP ...
Posted: Wednesday 24 July 2019 15:30
by ejsmith
Hi guys,
A short update to mention that I had similar issue with my rasberry PI 3 with raspberian and domoticz.
2019-07-24 00:11:55.472 Status: EventSystem: Started
2019-07-24 00:11:55.472 Status: EventSystem: Queue thread started...
2019-07-24 00:11:55.477 Status: PluginSystem: Entering work loop.
2019-07-24 00:13:34.159 Error: EventSystem thread seems to have ended unexpectedly (last update 82.000000 seconds ago)
2019-07-24 00:13:34.160 Error: Scheduler thread seems to have ended unexpectedly (last update 82.000000 seconds ago)
Which, after reboot, provoked domoticz to end in the state "active (exited)".
I just disabled blue tooth and the error is gone!
