Page 1 of 3
Eurotronic Comet z-wave Thermostat does not seem to work
Posted: Thursday 10 December 2015 20:19
by dacora
Hi All.
So I've installed a Eurotronic Comet z-wave Thermostat and I can find it and see it in domotiz.
I've also been able to set the wakeup time alright.
However I am not sure if setting the setpoint works.
Here is a log from setting it:
2015-12-10 19:53:49.438 Info, Node004, Sending (WakeUp) message (Callback ID=0x11, Expected Reply=0x04) - WakeUpCmd_IntervalGet (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x84, 0x05, 0x25, 0x11, 0x56
2015-12-10 19:53:49.447 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-12-10 19:53:49.447 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2015-12-10 19:53:49.463 Detail, Node004,   Received: 0x01, 0x05, 0x00, 0x13, 0x11, 0x00, 0xf8
2015-12-10 19:53:49.464 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x11 received (expected 0x11)
2015-12-10 19:53:49.464 Info, Node004, Request RTT 25 Average Request RTT 28
2015-12-10 19:53:49.464 Detail,   Expected callbackId was received
2015-12-10 19:53:49.475 Detail, Node004,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x04, 0x06, 0x84, 0x06, 0x00, 0x07, 0x08, 0x01, 0x79
2015-12-10 19:53:49.475 Info, Node004, Response RTT 36 Average Response RTT 35
2015-12-10 19:53:49.475 Info, Node004, Received Wakeup Interval report from node 4: Interval=1800, Target Node=1
2015-12-10 19:53:49.475 Detail, Node004, Initial read of value
2015-12-10 19:53:49.475 Detail, Node004,   Expected reply and command class was received
2015-12-10 19:53:49.475 Detail, Node004,   Message transaction complete
2015-12-10 19:53:49.475 Detail, Node004, Removing current message
2015-12-10 19:53:49.475 Detail, Node004, Notification: ValueChanged
2015-12-10 19:53:49.505 Detail,
2015-12-10 19:53:49.505 Info, Node004, Sending (WakeUp) message (Callback ID=0x12, Expected Reply=0x13) - ThermostatSetpointCmd_Set (Node=4): 0x01, 0x0c, 0x00, 0x13, 0x04, 0x05, 0x43, 0x01, 0x08, 0x01, 0x18, 0x25, 0x12, 0x85
2015-12-10 19:53:49.512 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-12-10 19:53:49.512 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2015-12-10 19:53:49.530 Detail, Node004,   Received: 0x01, 0x05, 0x00, 0x13, 0x12, 0x00, 0xfb
2015-12-10 19:53:49.530 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x12 received (expected 0x12)
2015-12-10 19:53:49.530 Info, Node004, Request RTT 25 Average Request RTT 26
2015-12-10 19:53:49.530 Detail,   Expected callbackId was received
2015-12-10 19:53:49.530 Detail,   Expected reply was received
2015-12-10 19:53:49.530 Detail,   Message transaction complete
2015-12-10 19:53:49.530 Detail, Node004, Removing current message
2015-12-10 19:53:49.530 Info, Node004, Sending (WakeUp) message (Callback ID=0x13, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x43, 0x02, 0x08, 0x25, 0x13, 0x9e
2015-12-10 19:53:49.538 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-12-10 19:53:49.538 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2015-12-10 19:53:49.555 Detail, Node004,   Received: 0x01, 0x05, 0x00, 0x13, 0x13, 0x00, 0xfa
2015-12-10 19:53:49.555 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x13 received (expected 0x13)
2015-12-10 19:53:49.555 Info, Node004, Request RTT 24 Average Request RTT 25
2015-12-10 19:53:49.555 Detail,   Expected callbackId was received
2015-12-10 19:53:59.531 Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s)
2015-12-10 19:53:59.531 Always,
2015-12-10 19:53:59.532 Always, Dumping queued log messages
2015-12-10 19:53:59.532 Always, End of queued log message dump
2015-12-10 19:53:59.532 Detail, Node004, Removing current message
2015-12-10 19:53:59.532 Detail, Node004, Notification: Notification - TimeOut
2015-12-10 19:53:59.532 Detail, Node004, Query Stage Complete (Session)
2015-12-10 19:53:59.532 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2015-12-10 19:53:59.532 Detail, Node004, QueryStage_Dynamic
2015-12-10 19:53:59.532 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0x14, 0xf6
2015-12-10 19:53:59.532 Detail, Node004, Queuing (Send) SensorMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x31, 0x04, 0x25, 0x15, 0xe6
2015-12-10 19:53:59.532 Detail, Node004, Queuing (Send) ThermostatModeCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x40, 0x02, 0x25, 0x16, 0x92
2015-12-10 19:53:59.532 Detail, Node004, Queuing (Send) BatteryCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x80, 0x02, 0x25, 0x17, 0x53
2015-12-10 19:53:59.533 Detail, Node004, Queuing (Query) Query Stage Complete (Dynamic)
2015-12-10 19:53:59.533 Info, Node004, Sending (Send) message (Callback ID=0x14, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0x14, 0xf6
2015-12-10 19:53:59.540 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
I notice that when it calls the ThermostatSetpointCmd_Get it seems to fail. Could that cause the thermostat to not set the setpoint?
Also do I need to make a manufacturer specific xml file or is it sufficient to use the zwcf_****.xml one, which I assume was generated by openzwave itself?
Re: Eurotronic Comet z-wave Thermostat does not seem to work
Posted: Thursday 10 December 2015 20:35
by Domosapiens
Posted: Friday 11 December 2015 21:06
by dacora
Yeah saw that one. I was the one asking for it :lol:
Anyway. Someone made a commit to the repo with the xml:
https://github.com/domoticz/domoticz/co ... a2ce2f5699
So I used that one and it work. I assume it will find its way to the stable at some point
Posted: Saturday 12 December 2015 0:13
by Domosapiens
That is great & fast !
Like to invite you to share your experiences here Z-Wave factfiles
as soon as you feel comfortable to do that.
You seem to have a product working, where many people are looking for !
To make sure ... it is this one?
Z-Wave Radiator Thermostaat zbild1-6592845C39-00J_250.JPG (7.83 KiB) Viewed 6593 times
Domosapiens
Posted: Monday 14 December 2015 1:20
by lightbullet
Be aware that the setpoints are not read out. You have to set them in the Domoticz GUI. This is beacause THERMOSTAT_SETPOINT are not in the polling list of Domotiz. By the way there is now a new config version pulled to the OpenZwave github https://github.com/OpenZWave/open-zwave/pull/710
Posted: Tuesday 05 January 2016 11:35
by scrappy
I'm trying to get the Comet Z-Wave working with my Aeon Labs Gen-5 usb stick and it seems to function OK using the Domoticz OpenZWave Control Panel. I set the wakeup time to the minimum 240 seconds (4 minutes) and in the Control Panel is see the device waking up every 4 minutes, however in Domoticz the setpoint devices and thermometer don't seem to update every 4 minutes. The 'last seen' just isn't being updated.
Also the devices that are added are 3 stepoints and 1 thermometer. No device to set the operation mode from Economy to Comfort.
Update: removed all devices so they are re-added upon a new scan and now I see more updates coming by which is good. Still no switch in Domoticz to switch operation mode, but I can probably manage by just adjusting the current set-point.
Posted: Friday 08 January 2016 18:44
by rickvanakkeren
Hi scrappy,
I have the same setup as you have (domoticz, Aeon stick Gen 5 and Comet Z-wave). Can you explain (step by step) how you removed and re-added the devices? I'm pretty new to Domoticz ánd Z-wave, so this is one big mystery for me.
Thanks for helping!
Rick
Posted: Monday 11 January 2016 8:35
by scrappy
Hi Rick,
to remove the devices go to the devices screen, select the devices you want to remove and then press the uber-small-hardly-visible-trash-can-icon (the one next to the invert-selection arrow in the header of the table, look closely, it took me ages to find it).
I don't know what exactly happened with my setup yesterday, but for some reason the temperature sensor failed and it got really warm in my room. Maybe it was due to the batteries running empty. This morning I switched batteries, removed all devices again and now it seems to work ok.
Posted: Monday 11 January 2016 9:45
by rickvanakkeren
Thanks for your reply scrappy. Unfortunately, I doens't seem to work great. The Thermostat is recognized in Domoticz
003 (0x03) Radiator EUROtronic EUR_COMETZ Wall Radiator Thermostat Valve Control 2016-01-09 13:44:03 Yes
But as you can see, the last time it was seen, was two days ago. I cannot change Wake-up interval (is set to 604620). When I change it, it automatically changes back to 604620. I removed the devices as you said, but they aren't coming back.
And can you maybe explain which devices you have now in Domoticz and how you control the thermostat?
Thanks again!
Posted: Monday 11 January 2016 11:00
by scrappy
Ah yeah the wake-up interval that was a headache for me as well. I noticed that controlling the Comet works better in the 'Control Panel'. To reach the control panel go to setup->hardware and enter the setup of the OpenZWave device. There's a 'Node Management' button at the top right of the table, press it and enter the 'Control Panel'. In the panel select the Comet go to the information tab and try to setup the wake-up interval there. Change it initially to 240 until everything works for you.
You can only change the wake-up time when the device is up but since the default interval is ssooo huge it won't every wake-up again. So remove the batteries, wait a few secs, put them back in and the Comet will enter 'installation mode'. This is you chance to set the wake-up time and this should get you in the right direction.
I further used the control panel to set the Comet into 'energy saving mode' and use energy saving mode setpoint to control the temperature, you could also use the comfort setpoint.
Posted: Tuesday 12 January 2016 22:44
by rickvanakkeren
Thanks for your reply. I couldn't get it to work. I also tried it to make it happen on my laptop, so I installed the Z-wave stick into m laptop and installed HomeGenie. Same there: I can see the node, but whatever command I'm sending, I get a time-out... Start thinking one of those two devices is broken...
Posted: Tuesday 12 January 2016 22:49
by scrappy
I can't seem to get the temperature sensor back now. I'll try to delete and re-add the device probably tomorrow.
Posted: Wednesday 13 January 2016 13:32
by scrappy
rickvanakkeren wrote:Thanks for your reply. I couldn't get it to work. I also tried it to make it happen on my laptop, so I installed the Z-wave stick into m laptop and installed HomeGenie. Same there: I can see the node, but whatever command I'm sending, I get a time-out... Start thinking one of those two devices is broken...
are you using rechargeable batteries by any chance?
Posted: Wednesday 13 January 2016 13:48
by rickvanakkeren
No using normal batteries. I've used new ones btw
Posted: Wednesday 13 January 2016 22:18
by Panda
Do you guys recomend this thermostat, or should I wait for better support for this device?
Posted: Thursday 14 January 2016 0:45
by rickvanakkeren
The thermostat isnt working here with a zwave stick and domoticz. I spoke to the reseller and will switch this one for a danfoss zwave
Posted: Thursday 14 January 2016 13:56
by scrappy
rickvanakkeren wrote:The thermostat isnt working here with a zwave stick and domoticz. I spoke to the reseller and will switch this one for a danfoss zwave
The reseller isn't robbshop by any chance?
Posted: Wednesday 20 January 2016 9:06
by scrappy
Also interested how the danfoss is working for you. I haven't given up on the Comet yet. For some reason I see communication between the stick and the Comet in the Control Panel logs, but the devices in Domoticz aren't updated.
Posted: Wednesday 20 January 2016 11:47
by Westcott
I've ordered one of these.
It's to go with a StellaZ that I've just about got working.
I can set the setpoint, read the temp, and change the valve level.
I can also change the mode with OZW panel, but not to direct control.
Sometimes it stops reporting - changing the wakeup interval slightly seems to fix that.
Posted: Friday 22 January 2016 23:29
by mKotek
I have also purchased Comet and connected it to Domoticz using UZB1 stick.
I was able to read temperature, but could not get information, which of the 3 setpoints are which, so it will take some time.
Of course I have not updated the wakeup interval and now my Comet went to sleep.
I also seem to be having totally off temperature reading from Comet. Of course I will adjust it using Domoticz sensor configuration, but I am quite surprised by this - it has been reporting 25,5 degree C, where there is 21 deg max. Of course I understand, temp is being measured next to the heater, but what is the point in having this reported if this is the case?
I have the following created automatically (except for names and setpoint values):
  	113	Z-wave_stick	0000307	1	SetP3	Thermostat	SetPoint	23.0	-	-
  	112	Z-wave_stick	000030B	1	SetP2	Thermostat	SetPoint	24.0	-	-
  	111	Z-wave_stick	0000301	1	SetP1	Thermostat	SetPoint	25.0	-	-
  	110	Z-wave_stick	0000301	1	Z-waveStick Level	Lighting 2	ZWave	Off	-	-
  	109	Z-wave_stick	00000301	1	Termo-KorG Status	General	Thermostat Mode	Heat	-	100
  	108	Z-wave_stick	0301	1	Termo-KorG	Temp	TFA 30.3133	25.5 C	-	100
UPDATE 2016/01/25: Some answers and new questions below.
I have the following questions:
1. Is Level is the level of signal from Z-wave? Answer: it is the level at which pin is retracted or otherwise extended in Comet.
2. What will happen, if I turn it on or move slider towards 100%? Answer: for some reason, Comet somehow fights it back - I set it to eg. 60% and it retracts it back to 41%,. No logic visible.
3. How to underdstand, which setpoint is which? I have found out, one is for comfort, one for eco and one stays at 0 and nothing can change it. I am still not clear, how to control the Comet correctly, which settings to change, only Setpoint value (seems to be popular among users) or to move slider or what to do?
The only thing I am sure after fighting with the device for 4 days is, the temperature reported is not being updated at regular intervales (no polling set, as it eats up battery incredibly fast, since device does not sleep then).
