History lost after battery swap, no reconnect
Posted: Thursday 10 December 2015 19:08
by ubfssF
I have several different types of temperature sensors, which seem to share a common feature: when I swap batteries the sensors don't reconnect afterwards under the same idx (with RFXtrx433-ext). I can only add them as new sensors, which means that I loose the history of the former device id's.
Is there a workaround for this? I would like to keep the history
Re: History lost after battery swap, no reconnect
Posted: Thursday 10 December 2015 19:48
by hansrune
Yes. Add the new device with a new name. Then click Edit on the original device, then click Transfer, then select the new device. Finally, clean up by deleting the old device, then rename the new one.
Blockly code must also be updated with the new device
Sent from my iPad using Tapatalk
Posted: Friday 11 December 2015 7:33
by jannl
Yes. I would be nice if the idx of the old device was used.
Posted: Friday 11 December 2015 22:03
by ubfssF
Thanx!
