VirtualHere - Sharing USB devices over network
Posted: Thursday 10 December 2015 11:21
I was browsing the web, and came across this: http://virtualhere.com/home
I don't use this software, but just wanted to share it here.
Also have a look at a Serial to Ethernet converter, i use this one to share my OTGW over LAN. This makes me free of having my server near the OTGW. Luckily Domoticz already has native support for reading the OTGW over network, which makes this a easy solution.
If you wish you could also make your smartmeter available over network with that serial to ethernet converter. Domoticz also supports a P1 over LAN.
Only requires a bit of soldering to connect it physically to your smart meter.
For Z-Wave i don't know, i think you have to use the VirtualHere software, or something similar like 'ser2net' or 'socat' which can be ran on a Raspberry or old router with DD-WRT / OpenWRT. I only don't know how to map that back (client part).
In theory, i think you should even be able to run your Domoticz somewhere in the cloud (virtual private server (VPS)) and map your USB-devices over network with stuff like this VirtualHere
It seems quite easy to use. Very handy if you run Domoticz in a virtual machine and have a USB-device (RFXCOM / Z-Wave / P1) somewhere else in your house, that you want to connect to the VM.VirtualHere allows USB devices to be used remotely over a network just as if they were locally connected!
