monitor wall plug from washing machine
Locked
derjungewilde
Post by derjungewilde »
I'm new with Domoticz and LUA.
I want to monitor my wall plug for the washing machine to tell me if the laundry is done.
Below is a LUA script from a fibaro froum. 161 is the id for the wall plug in the fibaro system. 45 for the smartphone.
How does the script has to look like for Domoticz and will it be possible to do that.
sorry for my bad english
thanks and regards
Alex
<code>--[[
%% properties
161 value
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger[&'type'] == 'property') -- Trigger wall plug
   then
   fibaro:sleep(600000);    -- 10 min delay
   local wallplug =  (tonumber(fibaro:getValue(161, 'value')) > 0 ); -- get wall plug status
  if (Wallplug)
    then
      while true do
       local PushOff = (tonumber(fibaro:getValue(161, 'valueSensor')) < 8 ); -- Wallplus < then 8 watt
       if (PushOff) then
        fibaro:call(45, 'sendPush', 'laundry is done'); -- send push message tosmartphone
        fibaro:call(45, 'sendPush', 'wall plug will turn off'); -- send push message tosmartphone
        fibaro:call(161, 'turnOff');  -- wallplug off
        break;
       fibaro:sleep(60000);
</code>
ThinkPad
Re: monitor wall plug from washing machine
Post by ThinkPad »
I have this already working with a Lua script for Domoticz, see this topic: http://domoticz.com/forum/viewtopic.php ... 187#p64660
As this topic is now duplicate, i will close it.
Locked
