Installing Domoticz under IIS
Posted: Sunday 06 December 2015 6:21
by jeremiahlandi
I am just tarting to play with Domoticz and it is awesome! I am running and IIS server on my computer. I would like to run the app under IIS instead. Is there a way to do this?
Any help would be great. Thank you.
Re: Installing Domoticz under IIS
Posted: Sunday 06 December 2015 11:56
by stlaha2007
Hi there,
Have you read manual and wiki's. Domoticz has its webserver integrated. And is controllable "remotely" with json htm-requests.
Dont know latest options with IIS, but consider virtual host with reverse proxy or build virtual directory with a custom frontpage which redirects on the background to your domoticz server/instance.
By default domoticz runs on ports 8080 and 443. So modify startup script to prevent blocking ISS or domoticz or use secondary ip to bind ISS or domoticz on that.
Sent from my K00C using Tapatalk
