I tried to install USBserial package. Sadly enough the DS216play is not in the INFO file.
Tried to put "monaco" in as additional architecture, but the drivers can not be installed.
Now i can not uninstall the package.
Two questions:
1. How can i uninstall it ?
2. Can you compile the package for the 216play ?
best regards
Norbert
Synology 216play
- jumbotroll
Re: Synology 216play
UsbSerialDrivers has not support for arch-monaco atm, maybe I will make it later.nsnnsn wrote:Hello,
Two questions:
best regards
Norbert
You have to stop all software that use USB drivers before you are allowed to uninstall UsbSerialDrivers package.
If that not work, you have to manually remove the package with winscp or a similar software.
I will download the toolchain for DS216play (arch-monaco) and cross compile domoticz that include USB drivers.
Let you know when you can download a test for DS216play.
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- jumbotroll
Her you can download a test for DS216play arch-monaco.
Domoticz V2.3771 with USB drivers and OpenZwave.
http://www.jadahl.com/beta.html
UsbSerialDrivers_3.0.5.spk is updated with arch-monaco for DS216play.
http://www.jadahl.com/drivers.html
Jumbotroll
Jumbotroll
Jumbotroll
Jumbotroll
nsnnsn
I tried to remove the old drivers but that went wrong.
Removed the directory: /volume1/@appstore/UsbSerialDriver
Now i still can not install...
what exactly do i need to remove the old package ?
There is not something like ipkg or opkg ?
- jumbotroll
You also need to remove /var/packages/UsbSerialDriversnsnnsn wrote:Hello,
You don't need UsbSerialDrivers package when you using my domoticz build.
My domoticz spk include all needed USB drivers.
You can manually remove UsbSerialDrivers with SSH.
With SSH:
From the command line you can just remove the directory 'rm -rf /var/packages/UsbSerialDrivers' and/or /volume1/@appstore/UsbSerialDrivers
After that reboot your NAS and install the latest domoticz spk for your NAS (arch-monaco)
Jumbotroll
Jumbotroll
Jumbotroll
