Attach scene to double-click Z-Wave.me dimmer 05458
Posted: Thursday 03 December 2015 16:38
by RoyT
My ZME_05458 dimmer has the ability to start scenes by double-clicking, but I have not yet been successful to detect this with Domoticz on my Raspberry Pi with RaZberry. I noticed that someone else had a similar issues with their Fibaro dimmer, but unlike them I don't see a new device in the device list, nor does it get picked up by "Add device" in the scene manager.
This probably has to do with the slightly different settings of the Z-Wave.me dimmer, but their documentation isn't all to clear on that. The parameter that I can change is:
Action on button double press or hold (Parameter Number 14, Parameter Size 1)
Defines which command should be sent on button double press or press-hold. Basic and Scene Activation commands are sent to Association group. Use Scene Controller Conf to set up Scene ID for Scene Activation. (...)
Another manual floating around says:
Relevant options are (next to "disabled", "switch all", etc):
3: Send Scenes
5: Send Preconfigured Scenes
That's it. Nothing about what "Scene Controller Conf" is, how to or why to set up a "Scene ID", etc. Does anyone have a clue to what I should do? :-)
Re: Attach scene to double-click Z-Wave.me dimmer 05458
Posted: Thursday 03 December 2015 19:50
by gizmocuz
do you use openzwave with your razberry ? if not -> failure
Posted: Thursday 03 December 2015 23:15
by RoyT
Yes, I do.
Posted: Friday 04 December 2015 7:21
by gizmocuz
According the manual
Group 2: Double press and press-hold of up/down buttons (max. nodes in group: 14)
did you at the controller (node 1) to group 2 also ? (so group 1 and group 2)
Posted: Friday 04 December 2015 9:42
by RoyT
Thanks for the input! Not sure if I understand you correctly. According to that part of the manual, I can double press-and-hold to associate another device. What am I supposed to do (in Domoticz?) to make the dimmer recognize the RaZberry as another device it can control?
Posted: Friday 04 December 2015 10:00
by gizmocuz
From the openzwave hardware setup, select 'groups and network' from the dropdown
then assign node 1 (the controller) to group 2 (by clicking the + button)
Posted: Saturday 05 December 2015 11:15
by RoyT
So I'm clearly brand new to z-wave ;)
Right now I have done this ("unknown" is this dimmer):
Which, if I understand the documentation of both Z-Wave.me and Domoticz correctly, have the controller in the same group as the doubleclick action. But: where in Domoticz do I actually see the ability to attach a scene or whatnot to that action?
PS: Who can clue me in on what "1.1", "1.2" and 1.3" mean?
Posted: Saturday 05 December 2015 11:18
by gizmocuz
If possible i would only try to put '1' in the groups not 1.1 and 1.2 (if its possible)
do you receive it now in domoticz?
Then head over to scenes/groups, and create a new one, learn the code from this button to it, and place your devices in it
Posted: Saturday 05 December 2015 11:42
by RoyT
I appreciate the patience gizmocuz :-) So, I only have node 1 in Group 2 now (removed all the rest). How do I know if I receive it in Domoticz? Doubleclicking the dimmer doesn't seem to add a new device, nor does "add device" for activation devices find the event when I doubleclick the dimmer button. But maybe I'm missing something obvious, being new to this.
Posted: Saturday 05 December 2015 12:28
by gizmocuz
I would also add node 1 in group 2 (just in case, maybe not needed)
Then in the settings page, enable 'accept new hardware', and observe the log, hope it gets added now
Posted: Monday 07 December 2015 13:03
by RoyT
I'm at a loss :-) I've added node 1 to groups 1 and 2 (and 3, but that's unrelated to this afaik), checked "accept new hardware", but double clicking the button doesn't add a new device in Domoticz (nor does clicking the button on the "push button on remote" prompt for the scene editor). Given that the dimmer and RaZberry card both are from Z-Wave.me, I'd assume that compatibility there isn't the issue.
Am I wrong in expecting the double click to shown up as a new device?
Posted: Monday 07 December 2015 13:20
by radem205
Did you try to add a device by creating a scene and press the button 'Add device' under 'Activation devices'? Thereafter, you need to press the button of the switch twice.
Posted: Monday 07 December 2015 14:24
by RoyT
I did that, but it times out without finding any devices :(
Posted: Tuesday 08 December 2015 12:54
by RoyT
I'm receiving a Fibaro FGD-212 today, just to make sure that it isn't me not understanding the setup, nor a faulty RaZberry z-wave implementation.
