Blockly User Variables not updating
bluepi
Post by bluepi »
Hello
I am having a few issues with user variables not being updated. Is there a reason you can see why this script will not reset the variable to 0
It updates fine to 1 from pause or play but will not do any thing with off??
Thank you
Domoticz V2.3530
https://drive.google.com/file/d/0B_cqMJ ... sp=sharing
bluepi
Re: Blockly User Variables not updating
Post by bluepi »
Well I thought I would update this...
Seems I was having two issues.
If my kodi is off it does not report being off (Not sure if this is because its being run on a raspberry Pi), which was then causing the script to fail and hence not update the variable.
However I also discovered that no mater what I did I could not trigger a blockly script based on a variable change i.e.
if variable = 1 then turn on light.
regardless of how I triggered the variable (from a script or manually)
So I re-wote all the blokly scripts in lua (gave me a chance to learn a new language) and everything works much better... All my triggers fire whenever a variable is changed or set.
Not sure why I did not get any help on this? was it posted in the wrong place?
