no new nodes are added to the gateway
Posted: Monday 30 November 2015 23:04
by bgitmans
I have a problem with the my sensors gateway.
I'm unable to connect any node to the gateway after I had to reinstall the complete system after a power failure that corrupted the SD card.
I reinstalled the whole system using the SD card image, and after that I restored my backup I made earlier.
But now I can see the Gateway that is connected, however no nodes are being added to the system anymore.
What could be the problem?
Re: no new nodes are added to the gateway
Posted: Tuesday 01 December 2015 0:08
by malarcy
Setup - Settings - Accept New Hardware devices?
Posted: Tuesday 01 December 2015 7:44
by bgitmans
That solution works for devices attached to rfxcom gateways, however not for a mysensor network. Previosly i had to assign a different node id manualy otherwise the nodes would end up in a already excisting node.
Posted: Tuesday 01 December 2015 8:59
by gizmocuz
the above solution is for all hardware/sensors, also mysensors
you can also try to reset your gateway, that is, writing/executing the clear eprom sketch
Posted: Tuesday 01 December 2015 13:06
by rmtucker
I had this problem yesterday with the beta versions but as soon as i switched back to stable version all were working again??
Posted: Wednesday 02 December 2015 18:05
by bgitmans
I've solved the problem by switching to an ethernet based gateway, now everything works fine.
And indeed use the "accept New Hardware" button.
Posted: Thursday 03 December 2015 16:22
by malarcy
I think mysensors nodes "remember" their node ID if you don't specify it in the sketch they get one automatically when they first connect and keep that value in eeprom. There's a clear eeprom sketch available to reset this info. I have found if I repurpose one then domoticz sees the old sensors and any new ones I have added when I look at the hardware. I usually manually delete the old unused sensors if the latest "thing" doesn't present them.
