Fibaro Door/Windows sensor device list
assenzuid
Post by assenzuid »
I have one Z-wave device attached to Domoticz, a Fibaro door/window sensor with a temp sensor.
In my device list 4 Z-Wave devices are showing
The one with ID 0000300 is for detecting if a door is open or closed, the temp sensor is also clear to me.
But the two other devices I haven't a clue for it.
can some one explain it to me?
Also I'm trying figuring out how Domotizc can detect if the case is opened (sabotage).
rgroothuis
Re: Fibaro Door/Windows sensor device list
Post by rgroothuis »
Seems to me you are a lucky guy to have the Fibaro door sensor working. I cannot get it to work together with a USB Zwave stick. I already started a viewtopic.php?f=24&t=8867 on this problem.
assenzuid
Post by assenzuid »
To add the sensor to Domticz took some effort..... using Razberry z-wave controller
rgroothuis
assenzuid wrote:To add the sensor to Domticz took some effort..... using Razberry z-wave controller
Yes I know. And then the next challenge for how long will it run stable. How long do you have it running now without any problems?
assenzuid
Post by assenzuid »
A few days, temp sensor is not really updating.
Verstuurd vanaf mijn HTC One met Tapatalk
pvm
Domoticz version: 4.10538
Post by pvm »
I also use a Fibaro door sensor (Incl. Temperature). No problems here.
One of the remaining devices is a switch for tampering detection (messing with the device) last one I don't remember
