My radio clock comes with a wireless outdoor sensor with measures the outside temperature. Does anyone checked the compatibility with Domoticz via the RFX USB interface (connected to Synology)?
Thanks.
Tronix
Philips outdoor temperature sensor
dijkdj
Re: Philips outdoor temperature sensor
Maybe you can tell us a bit more about the radio en the sensor. Did you check the compatibility list?
tronix
Sure. It's a Philips AJ7010/12 clock radio. It's using a wireless sensor, which only has the text "outdoorsensor" out it. I don't recognize it in the compatibility list.
Tronix
Tronix
- gizmocuz
i can not find in the manual if it operates on 433 or 868 mhz , do you know this?
if not, than it will not work...
SweetPants
Then it is not supported. You need at least know the way the sensor is communicating with the radio, 433, 686, Wifi, Bluetooth etc etc. Without more information it is hard to tell.tronix wrote:I don't recognize it in the compatibility list.
