Zwave and kaku
Jango
Zwave and kaku
Post by Jango »
I have a question about my raspberry with rfxcom.
Can i control zwave and klik aan klik uit together?
jvdz
Domoticz version: 4.107
Re: Zwave and kaku
Post by jvdz »
You can't control ZWAVE with RFXCOM.
When you also attached an ZWAVE controller next to the RFXCOM, you will be able to control both ZWAVE and KAKU.
Jos
Jango
Re: Zwave and kaku
Post by Jango »
If I buy an usb zwave stick that plugs in the raspberry, Is that enough?
Which usb stick would you advice?
Egregius
Domoticz version: v2024.7
Re: Zwave and kaku
Post by Egregius »
Works perfectly together. The mix of different hardware is de biggest advantage of Domoticz.
I have rfxcom and Aeon Z-stick but I guess you should go for Zwave+ stick now.
Jango
Re: Zwave and kaku
Post by Jango »
Thanks for the quick response
jvdz
Re: Zwave and kaku
Post by jvdz »
That is indeed what I have: and RFXCOM E USB with a OpenZWave USB and they work very nicely together.
Jos
