Combine sketches
Posted: Sunday 29 November 2015 10:12
by thecosmicgate
At the moment I've got running the 3 in 1 sketch : motion , temperature, moisture .
But I want to combine the battery monitoring sketch .
Is there somebody who can help me with this ?
Thnx a lot
Sent from my MotoG3 using Tapatalk
Re: Combine sketches
Posted: Sunday 29 November 2015 11:42
by sundberg84
#define VBAT_PER_BITS 0.003363075 // Calculated volts per bit from the used battery montoring voltage divider. Internal_ref=1.1V, res=10bit=2^10-1=1023, Eg for 3V (2AA): Vin/Vb=R1/(R1+R2)=470e3/(1e6+470e3), Vlim=Vb/Vin*1.1=3.44V, Volts per bit = Vlim/1023= 0.003363075
#define VMIN 1.9 // Battery monitor lower level. Vmin_radio=1.9V
#define VMAX 3.3 // " " " high level. Vmin<Vmax<=3.44
int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
int oldBatteryPcnt = 0;
In setup:
analogReference(INTERNAL); // use the 1.1 V internal reference for battery level measuring
In loop:
int sensorValue = analogRead(BATTERY_SENSE_PIN); // Battery monitoring reading
// Serial.println(sensorValue);
float Vbat = sensorValue * VBAT_PER_BITS;
// Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" V");
//int batteryPcnt = sensorValue / 10;
int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
// Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
if (oldBatteryPcnt != batteryPcnt) {
gw.sendBatteryLevel(batteryPcnt);
oldBatteryPcnt = batteryPcnt;
Posted: Sunday 29 November 2015 13:34
by thecosmicgate
sundberg84 wrote:#define VBAT_PER_BITS 0.003363075 // Calculated volts per bit from the used battery montoring voltage divider. Internal_ref=1.1V, res=10bit=2^10-1=1023, Eg for 3V (2AA): Vin/Vb=R1/(R1+R2)=470e3/(1e6+470e3), Vlim=Vb/Vin*1.1=3.44V, Volts per bit = Vlim/1023= 0.003363075
In setup:
In loop:
I can copy paste this in the 3in1 sketch ?
Posted: Sunday 29 November 2015 17:25
by sundberg84
Yes, this is the battery code if you have a voltage divider described in
http://www.mysensors.org/build/battery# ... tery-level
Posted: Sunday 29 November 2015 20:05
by thecosmicgate
I'am going to buy the resistors .
But its that easy to open the 3in1 sketch and copy paste the battery sketch below this 3in1 sketch ?
Posted: Sunday 29 November 2015 23:40
by Domosapiens
Useless information detection:
Who cares?
Domosapiens
Posted: Tuesday 01 December 2015 18:54
by thecosmicgate
Domosapiens wrote:Useless information detection:
Who cares?
Domosapiens
Nobody
but thats some default on the tapatalk app on the mobile phone, had tot uncheck this
Posted: Wednesday 02 December 2015 12:03
by sundberg84
Yea, pretty much - copy and paste - try it out, run the sketch and debug on serial, thats how it is done.
You need to try instead, you will make it.
Posted: Wednesday 02 December 2015 12:07
by thecosmicgate
The sketch i created :
#include <SPI.h>
#include <MySensor.h>
#include <DHT.h>
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
#define CHILD_ID_MOT 2 // Id of the sensor child
#define HUMIDITY_SENSOR_DIGITAL_PIN 4
#define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
MySensor gw;
DHT dht;
float lastTemp;
float lastHum;
boolean metric = true;
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
void setup()
#if defined(__AVR_ATmega2560__)
analogReference(INTERNAL1V1);
#else
#endif
gw.begin();
dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
// Send the Sketch Version Information to the Gateway
gw.sendSketchInfo("Humidity/Motion", "1.0");
pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
// Register all sensors to gw (they will be created as child devices)
gw.present(CHILD_ID_HUM, S_HUM);
gw.present(CHILD_ID_TEMP, S_TEMP);
gw.present(CHILD_ID_MOT, S_MOTION);
metric = gw.getConfig().isMetric;
void loop()
// get the battery Voltage
#ifdef DEBUG
#endif
// 1M, 470K divider across battery and using internal ADC ref of 1.1V
// Sense point is bypassed with 0.1 uF cap to reduce noise at that point
// ((1e6+470e3)/470e3)*1.1 = Vmax = 3.44 Volts
// 3.44/1023 = Volts per bit = 0.003363075
float batteryV = sensorValue * 0.003363075;
#ifdef DEBUG
Serial.print(batteryV);
#endif
// Power up radio after sleep
// Read digital motion value
boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
Serial.println(tripped);
gw.send(msgMot.set(tripped?"1":"0")); // Send tripped value to gw
delay(dht.getMinimumSamplingPeriod());
float temperature = dht.getTemperature();
if (isnan(temperature)) {
Serial.println("Failed reading temperature from DHT");
} else if (temperature != lastTemp) {
lastTemp = temperature;
if (!metric) {
temperature = dht.toFahrenheit(temperature);
gw.send(msgTemp.set(temperature, 1));
Serial.print("T: ");
Serial.println(temperature);
float humidity = dht.getHumidity();
if (isnan(humidity)) {
Serial.println("Failed reading humidity from DHT");
} else if (humidity != lastHum) {
lastHum = humidity;
gw.send(msgHum.set(humidity, 1));
Serial.print("H: ");
Serial.println(humidity);
// Sleep until interrupt comes in on motion sensor. Send update every two minute.
gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
