problemi con domoticz
bibbi1969
Post by bibbi1969 »
hello congratulations for the forum and sorry for the language but use a translator.
I have a usb rpi2 with z-wave and domoticz v.23713, I bought a set of components fibaro: switch fgs211, fgk101, fgms001, fgbs001 to try them but I have problems:
I can not add new components in the network
those included are sleeping
I do not see the signal of wi-fi
where am I wrong?
thank you
pvm
Domoticz version: 4.10538
Re: problemi con domoticz
Post by pvm »
There's no WiFi on a RPI2 without extra hardware. For you use a aeon labs stick? Battery based devices are sleeping,that's OK. They wake every 2 hours by default to accept new settings. Mains powered devices however shouldn't sleep. You don't see devices in domoticz, or do you? When you see them,do you also see them in the general devices screen? Pressed add button there?
bibbi1969
Post by bibbi1969 »
thanks for the reply but I hurt demand:
in domoticz I not have the level of 868MHz
I managed to put some components in the node in the control panel -controller-add device, but the most pressing 'key twice inclusion does not find a door / window why?
livello wi-fi.pdf
(340.78 KiB) Downloaded 91 times
pvm
Post by pvm »
Do you use an aeon labs stick? The best way,in my opinion, to include devices is by taking the stick out of the pi and press it's button when near to the device and set the device in include mode
bibbi1969
Post by bibbi1969 »
problem solved now works well I upgraded to ver.23774. :D :D :D
grazie
