New Raspberry PI ZERO only $5 !!
maluko
Post by maluko »
There are a new raspberry pi on market, seems promissor. :)
its out of stock
https://www.raspberrypi.org/blog/raspberry-pi-zero/
Toni
Re: New Raspberry PI ZERO only $5 !!
Post by Toni »
It's a shame it doesn't have built-in network adapter (either Ethernet or WiFi). Of course you can use USB WiFi dongles, but you also need the Micro-USB to USB-A adapter.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
You need to invest at least in peripherals like PowerSupply and USB-hub, or is perhaps 1 powered USB-hub sufficient to make the device 'tick'?
2*micro-USB-connecion is not much, and already claimed for data and for power.
Any cheap USB-hub with at least one compatible micro-USB-connector for easy multiplication of the data-interface towards 'normal' USB-interfaces?
And then you have to create an interface to the outside-world.
Perhaps a clever supplier with a combi-adapter with micro-usb(s) at one side, with power, 'normal' USB & RJ45 at the other side?
Fitting a GPIO-header seems another useful addition for easy & safe interfacing.
Only then this device is ready 'to connect to the outside world'.
Conclusion: saving is significant in the price of the mainboard, but not in the peripherals.
Last edited by Toulon7559 on Monday 30 November 2015 8:27, edited 6 times in total.
gizmocuz
Post by gizmocuz »
Yep, i agree, for home automation it is useless, for other things it might be a nice peace of hardware
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
Got one today - given the price, one can utilise it locally in a wardrobe for, say, energy meter monitoring and publishing data in internet. Yes, the biggest blow to me is that it does not have a built-in WiFi.
maluko
Post by maluko »
i think it is possible to connect a esp8266 to pin and give possibility to have wifi (serial).
http://www.extragsm.com/blog/2014/12/03 ... pberry-pi/
Toulon7559
@maluko
A 'general' wifi-interface by just fitting an esp8266 to this mini-raspberry?
Perhaps you already assume it, but probably more is needed for the change you describe for the settings to the Raspberry:
either for remote access to the files on the Raspberry you have to make an Ethernet&Putty-connection to the Raspberry,
or alternatively for local-access at the Raspberry you have to connect a screen@HDMI + keyboard@USB.
[Or could your achieve the required effect by tweaking the files on the Raspberry's SD-card?]
After fitting an Ethernet-interface, why should you further fiddle with an ESP8266 for 'general' wifi?
Last edited by Toulon7559 on Monday 30 November 2015 22:15, edited 1 time in total.
alexsh1
Post by alexsh1 »
bassmint
Post by bassmint »
Has anyone run domo on a zero yet? I got a few of them the other day and am trying to decide what to do with them.
gizmocuz
Post by gizmocuz »
What did yo pay for it ?
I just pre-ordered this:
1x C.H.I.P. for $9.00 each
And it even sounds more fun:
http://getchip.com/
deennoo
Post by deennoo »
Great CHIP !
http://domo-attitude.fr
