how to know what protocol new and existing devices use?
Posted: Wednesday 25 November 2015 23:06
by Evelen
when I added my first devices I did not found it in domoticz with standard protocols, the solution was to enable all the protocols. have well read me afterwards that there is not necessarily a good idea.
The question then becomes:
- How do I know which protocol my stuff uses?
- And what about new devices that are not yet in domoticz?
- Uten navn.png (307.81 KiB) Viewed 2493 times
Re: how to know what protocol new and existing devices use?
Posted: Thursday 26 November 2015 11:01
by b_weijenberg
please see chapter 2.2.2 in the RFXtrx User Guide.
For each supported device you will find the protocol used.
For example NEXA learning mode uses the AC protocol. NEXA with address code wheels uses ARC.
Enable only protocols needed. Check also chapter 2.4 which protocols can be used together.
Posted: Thursday 26 November 2015 11:18
by Evelen
thanks, but i Can't Find my smoke detectors, "CLSF LM-101LB"
Posted: Thursday 26 November 2015 11:28
by b_weijenberg
I suppose this is a KD101 type.
Please check with RFXmngr if something received if you press the test button on the smoke detector.
You don't need to enable a protocol for the KD101.
Posted: Thursday 26 November 2015 21:16
by Evelen
worked
- ^56E55BF4E9D44D348E853B9A424266B99CCED86065DA66CBC2^pimgpsh_fullsize_distr.jpg (75.26 KiB) Viewed 2439 times
