Successor USB CO2 sensor
Posted: Tuesday 24 November 2015 20:35
I would like to measure indoor air quality. I want to do this by measuring the CO2 level. I've been searching for a reliable indicator without the hassle of calibration. I think that the K- 30(or S8) SenseAir sensor can satisfy those requirements. This sensor seems much better than the Voltcraft USB sensor (supported by Domoticz)
that’s no longer available. See also (sorry only Dutch) http://www.co2indicator.nl/co2-meter.ht ... Gwod--UNaw
I would like to connect the sensor to an RPI that can be connected as a slave to Domoticz through a WiFi dongle.
Due to this set-up, I can use the sensor for controlling the ventilation ( stationary set-up). But occasionally, I can also use the sensor for measuring, for example, the CO2 level in a bedroom. It’s also possible to add a DHT22 (already supported) for measuring the relative air humidity.
On the internet I found http://co2meters.com/Documentation/AppN ... series.pdf
Electrically coupling the sensor to the RPI is no problem. For me the problem is the necessary software. I'am stuck and need help, I’am a noob.
It would be great if this sensor is supported by domoticz , perhaps as a successor to the USB sensor. But all other help is welcome.
Thanks in advance
Thanks in advance
