Page 1 of 2
Wrong zwave switch level displayed On, 255 %
Posted: Tuesday 24 November 2015 12:41
by warp
-Raspberry pi2B with Domoticz V2.3678
-RaZberry with OpenZWave V1.3-550-g4a2b2e5
-Qubino ZMNHBA2 Flush 2 Relays
- Ok.PNG (6.17 KiB) Viewed 3903 times
I have several problems on my Qubino ZMNHBA2 :
The first :
1°) when i click on the
001C01,
- State reports to "On" for 001C01 -> Good Behaviour
- Step2.PNG (6.28 KiB) Viewed 3903 times
2°) when i click on the
001C02,
- State reports to "On" for 001C02 -> Goog Behaviour
State reports to "On,Level 255%" for 001C01 -> Why, Bad Behaviour ?
State reports RF Signal Level to "-" -> Why ?
- Step3.PNG (6.57 KiB) Viewed 3903 times
The second :
- when i click on the
001C02,
- State reports to "On,Level 255%" for 001C01 -> But the relay of the switch 001C01 is not at "On" !
It seems that other people have the same problem, right?
viewtopic.php?f=6&t=5698
viewtopic.php?f=17&t=7043
help me @gizmocuz..
Re: Wrong zwave switch level displayed On, 255 %
Posted: Tuesday 24 November 2015 13:06
by Egregius
Remove the 'mapping = endpoints' line at the bottom of the Config XML.
Then you'll have 3 switches. 2 & 3 will work properly then.
This isn't a actual problem of Domoticz but from Openzwave.
Posted: Tuesday 24 November 2015 20:49
by warp
Egregius wrote:Remove the 'mapping = endpoints' line at the bottom of the Config XML.
I have 3 switches now ..
But I still have problems:
When I click on the switch 2, switch State reports to "On"
When I click on the switch 3, switch 2 & 3 State reports to "On",
Posted: Tuesday 24 November 2015 21:40
by Egregius
And then use the script in
viewtopic.php?f=17&t=7043&start=40#p54276
Works fine here
Posted: Wednesday 25 November 2015 12:23
by warp
Thank you you got to answer @Egregius
I have two questions:
- 1) Or should we set this script ?
2) Have you opened a ticker in OpenZwave for this problem ?
For information I have a switch "Mcohome MH-S412 Two-load" with the 'mapping =endpoints' line at the bottom of the XML Config, and it Works fine .
- Mcohome MH-S412 .jpg (6.1 KiB) Viewed 3818 times
Posted: Wednesday 25 November 2015 12:52
by Egregius
Posted: Wednesday 25 November 2015 13:03
by warp
Where should we set this script php ?
Posted: Thursday 26 November 2015 17:42
by Egregius
Doesn't mather.
If you put it in the scripts folder you can call it by script://nameoffile.php
If it's somewhere else you'll need to specify the full path script:///path/nameoffile.php
Posted: Friday 27 November 2015 13:02
by warp
Egregius wrote:Doesn't mather.
Sorry but my question was, or should I interfaced the php script ?
- in cron?
- in the actions on-off of the switch?
- or other ?
Posted: Friday 27 November 2015 14:10
by Egregius
I have a refreshzwave in my script that runs after every switch update (thru domoticz_main)
If one of those switches is changed in the last 5 seconds I call the refreshzwave function for it.
//Refresh Zwave node
if($STTV>$time-5) RefreshZwave(10);
if($STLichtTerrasGarage>$time-5) RefreshZwave(16);
if($STLichtHallZolder>$time-5) RefreshZwave(20);
if($STLichtInkomVoordeur>$time-5) RefreshZwave(23);
if($STBureel_Tobi>$time-5) RefreshZwave(24);
if($STSubwoofer>$time-5) RefreshZwave(51);
if($STLamp_Bureel>$time-5) RefreshZwave(52);
if($STPluto>$time-5) RefreshZwave(53);
if($STKeukenZolder>$time-5) RefreshZwave(56);
I also have another that just runs by cron every 30 minutes. I like to call it custom polling
<?php
file_get_contents('http://127.0.0.1:8080/json.htm?type=openzwavenodes&idx=5'); //Change IDX to IDX of your zwave controller
function RefreshZwave($node) {
$zwaveurl='http://127.0.0.1:8080/ozwcp/refreshpost.html';
$zwavedata=array('fun'=>'racp','node'=>$node);
$zwaveoptions = array('http'=>array('header'=>'Content-Type: application/x-www-form-urlencoded\r\n','method'=>'POST','content'=>http_build_query($zwavedata),),);
$zwavecontext=stream_context_create($zwaveoptions);
for ($k=1;$k<=5;$k++){sleep(2);$result=file_get_contents($zwaveurl,false,$zwavecontext);if($result=='OK') break;}
RefreshZwave(10);
RefreshZwave(16);
RefreshZwave(20);
RefreshZwave(23);
RefreshZwave(24);
RefreshZwave(51);
RefreshZwave(52);
RefreshZwave(53);
RefreshZwave(56);
RefreshZwave(60);
RefreshZwave(61);
RefreshZwave(62);
RefreshZwave(63);
Posted: Wednesday 02 December 2015 16:39
by warp
@Egregius
Can you give me the exact code of your domoticz_main ?
Posted: Wednesday 02 December 2015 21:22
by Egregius
Sure
#!/bin/sh
curl 'http://127.0.0.1/secure/cron.php'
I use curl instead of /usr/bin/php because it allows use of xcache.
Posted: Friday 04 December 2015 2:25
by stolle
I got the same problem and is wondering if I shall exclude/include the device after removing the mapping=endpoint line?
Posted: Friday 04 December 2015 12:31
by warp
@Egregius
Posted: Friday 04 December 2015 16:24
by Egregius
Posted: Monday 07 December 2015 9:39
by warp
#!/bin/sh
@Egregius
Sorry but i could not find "cron.php"
Posted: Monday 07 December 2015 14:10
by Egregius
It's on my github, see link in signature below.
Posted: Wednesday 09 December 2015 19:59
by warp
Egregius wrote:It's on my github, see link in signature below.
Thank you, but your "cron.php" script is too complicated for me, I will have wished to have only the part concerning the problem of QUBINO ZMNHBA2.
Posted: Wednesday 09 December 2015 22:07
by Egregius
You only need the refreshzwave function.
There's a complete example in one of the other qubino topics.
Posted: Thursday 10 December 2015 11:48
by warp
@Egregius
Thank, for the cron.php and the refreshzwave function.
But if i want refresh after every switch update , how to do ?
